Looking for instructive material on IR transmitters/receivers
In summary, the author has questions about IR transmitters and receivers and needs help understanding the basics.
Noesis
101
Unfortunately I have not been able to find anything reasonable online.
I'd like an in depth all-inclusive explanation of IR transmitters and receivers, from a physical standpoint. I would also be glad to learn whatever else is included in the reading material, if anything.
I have basic questions such as: how close does the IR receiver need to be to the transmitter, does it need to be within its 'line of sight,' will there be significant interference from visible light (I assume so, which is why I see shielding and modulation occurring), and how does it all work in the first place. I suppose the latter concept might be found in a semiconductor physics book, but I am not sure.
Thank you very much.
Most of us have used a TV remote control, so you would have a feeling already for the range of IR control and the fact that it does travel in straight lines. It is just light even though it is infra red.
The range of a good remote control would be maybe 10 meters. More than enough to operate from anywhere in a large room or even a large class room in a school.
Yes, the better ones are always modulated. Actually, they are switched on and off rapidly at a rate of about 38 - 40 KHz and then this is switched a lot more slowly to carry data. There may be many functions on a remote control and there has to be a range of codes which can be sent to say which button you are pushing.
The rapid switching is to reduce problems with other light sources which may also put out infra red light. Even this isn't perfect, though, as some compact fluorescent lights put out pulsed infra red light and this can make a remote control for a TV set useless.
There are dedicated remote control receive chips and these are quite cheap and very good. They contain a phototransistor, a filter and an amplifier so that the fairly weak signal from the remote control can be amplified up to produce stable data output for the device being controlled.
Thanks..that is indeed helpful information, and it provides me sufficient to start building simple projects in this realm and graduate forwards.
Thanks again.
FAQ: Looking for instructive material on IR transmitters/receivers
1. What are IR transmitters and receivers?
IR transmitters and receivers are electronic devices used to send and receive infrared signals. These signals are used for remote control applications, such as controlling TVs, DVD players, and other electronic devices.
2. How do IR transmitters and receivers work?
IR transmitters use an infrared LED to emit a beam of infrared light. This light is then received by the IR receiver, which converts it back into an electrical signal. The receiver then decodes this signal and sends it to the device being controlled.
3. What types of devices use IR transmitters and receivers?
IR transmitters and receivers are commonly used in remote control devices, such as TVs, DVD players, and stereo systems. They are also used in security systems, automatic lighting systems, and other electronic devices that require remote control.
4. How can I learn more about IR transmitters and receivers?
There are many resources available for learning about IR transmitters and receivers. You can read articles and tutorials online, watch instructional videos, or consult books and manuals on the subject. You can also attend workshops or courses on electronics or remote control technology.
5. Are there any safety considerations when using IR transmitters and receivers?
Yes, there are some safety considerations when using IR transmitters and receivers. It is important to avoid looking directly into the IR beam, as it can cause eye damage. It is also important to handle the devices carefully, as they contain delicate electronic components. Always follow the manufacturer's instructions and use caution when working with these devices.
