Looking for some advice/guidance
  • Thread starter singen
In summary, a person wants to build a motorized lazy susan to test computer mice for maximum speed. They are looking for something that they can control and that will rotate at a speed of 5 to 10 meters per second. They are also looking for a solution that is cheap and easy to use.
singen
Hi, I figured this would be a good place to post a question regarding testing apparatus. I want to test various computer mice for performance (specifically maximum speed) and I'm looking to build (or buy) something that would be able to spin a flat disc at variable speeds. For a similar purpose I've seen someone use an old belt driven record player but I'd prefer something that I could have a little more control over. Does anyone have any simple and preferably affordable solutions? Thanks.
Edit* I should mention that I'm not an engineer or physicist.
After reading my initial post over and thinking about the problem some more I think I can more clearly explain the problem domain. Basically what I need is a motorized lazy susan. I thought of trying to get a simple turn table but I'd rather have more control. While it won't be required to move anything of substantial weight it will still need to move whatever mousepad I use for testing and there is some friction where the mouse is in contact with the mousepad. Also I'd like it to rotate at a speed of 5 to 10 meters per second (I would need the ability to adjust the speed in some small increments).
--Edit--
After quite a bit of searching I think I've found a good solution. My only question is how would I go about calculating my power requirements? I'll be spinning a wooden lazy susan @ 5 meters per second (my calculations tell me that a 15in diameter lazy susan would need to rotate at 250rpm to get my desired speed) so I'm not sure if simple toy motor would work or if Id need something a little more powerful.
If your looking to do this cheaply, you could use one of the small scooter motors with a belt drive or just driving your wheel directly and a regular scooter controller for it. That will give you from 0 to the max speed of the motor. Most of those 24/36 volt motors run a max speed of about 2500-3000 rpm. a 100 or 250 watt motor (standard outputs) should be plenty of power. Find a used one on craigslist or the local newspaper ads. 9 out 10 times the only thing that will be wrong with one is totally dead batteries where the charger died and was never replaced. I've used those little motors for all kinds of stuff.
It doesn't matter what you're actually spinning, whether its a lazy susan or just a piece of wood you buy at a hardware store. Just get something circular and put it on an axle in the middle. Cheap particle board would be the best option. Put a cloth surface over it so the mouse has something to track.
Why don't you just take a power drill that has a low-speed/high-torque mode, put a few hexagonal nuts on a screw to give the drill tip something to bite down on, and then connect the screw to a somewhat thin piece of wood/particle board. Put a sticker on the edge of the spinning piece, use a stopwatch to determine how long it takes for it to complete, say, 50 revolutions, and from that you can figure out its speed since you know its diameter.
By adjusting how far from the axle/center of the spinning wooden circle you place the mouse, you can change the tracking speed of the mouse.
You could test mice extremely quickly and accurately this way by starting reasonably close to the middle of the spinning disk and then moving towards the edge. Measure the radius at which the mouse starts producing errors, and using this value you can determine its max. tracking speed. The only issue here is that optical mice judge movement by rapidly imaging the surface below and calculating linear displacement between captured frames, and curvature, especially at the high speeds where they lose tracking, will be harmful to their performance. That is, the mouse might perform better on a treadmill spinning at 5 m/s than on a small circular disk whose surface directly under the mouse sensor is spinning at 5 m/s, since the movement of the treadmill surface is actually linear. Beyond a few inches from the axle, though, this will be negligible (which is why I'm suggesting you use the low-torque setting on the drill with a large circular surface rather than trying to spin a small disk very quickly).
What you *don't* want to do is put something like the wheel from an R/C car on the edge of the round Susan, because the wheel speed will be variable depending on how much juice the batteries have left and on how hard you're pushing the wheel down to get traction (too much = friction losses, too little = slippage). With the drill system above, you'll get reasonably consistent spin rates assuming you're using a corded drill and not a battery-powered one.
Hi there,
Thank you for reaching out for advice on testing apparatus for your project. I can offer some suggestions for your specific needs.
Firstly, I would recommend looking into purchasing a rotary motion sensor. This device can measure the rotational speed and acceleration of an object, and it can be connected to a computer for data collection and analysis. This would provide you with the control and accuracy you are looking for in your testing.
Another option would be to build your own apparatus using a motor, a disc, and a speed controller. This would require some knowledge of basic electronics and mechanics, but there are many online tutorials and resources available to help guide you through the process.
Additionally, you could also consider using a high-speed camera to capture the movement of the mouse and analyze its speed. This would not require any specialized equipment and could be a more affordable option.
I hope this helps guide you in finding a suitable solution for your project. Best of luck with your testing!
FAQ: Looking for some advice/guidance
1. What should I do if I am stuck on a research problem?
If you are stuck on a research problem, it is always helpful to seek advice or guidance from your colleagues, mentors, or professors. They may have insights or suggestions that could help you approach the problem from a different angle.
2. How do I choose a research topic?
Choosing a research topic can be challenging, but it is important to choose something that interests you and aligns with your expertise. You can also look at current trends and gaps in the scientific literature to find inspiration for a research topic.
3. How do I know if my research methodology is appropriate?
The appropriateness of your research methodology will depend on your research question and goals. It is important to thoroughly review and justify your chosen methodology in your research proposal or manuscript. Seeking feedback from peers and experts in your field can also help ensure the validity of your methodology.
4. What should I do if my results do not support my hypothesis?
If your results do not support your hypothesis, it is important to critically evaluate your data and methodology. You can also seek advice from your colleagues or supervisor to see if there are any other potential explanations for your results. Negative results can also lead to new research questions and directions.
5. How do I handle conflicting findings in my research?
Conflicting findings are common in scientific research, and it is important to thoroughly analyze and interpret your data. Consider the strengths and limitations of each study and try to find commonalities or differences that may explain the discrepancies. It can also be helpful to seek the opinions of other researchers in your field.
