RWS000
- 11
LOOKING FOR WEIGHT/MEASUREMENT DEVICE: DOES ANYONE HAVE ANY SUGGESTIONS?
Please bear with me. I think the best way to present this is to post my RFQ and that will, I hope, explain what I am looking for. AN ALTERNATIVE TO A NORMAL LOAD CELL, WHICH WOULD HOPEFULLY BE MUCH CHEAPER, WOULD BE GREATLY APPRECIATED.
PRODUCT DESCRIPTION:
A stainless steel washer type load cell, with bolt hole in center, that may measure the bolt compression force, then be “reset” or recalibrated to zero and be able to measure additional weight, for the range of 0 to 1000 lbs and/or metric system, put or loaded on top of the bolt head platform. The ultimate goal is to measure the net weight (0 to 1000 lbs) added to the top of the bolt head after the bolt has been tightened in place. The actual bolt compression force initially put on the load cell would be to anchor the cell down with enough force for it to be mechanically very tight. The measurement of that force is not really required, unless it required on your end as part of a washer type design. A consideration would be if a “reset” calibration would be more expensive to introduce to the design or a design that could allow the load cell not to start measuring until after the bolt anchoring compression had been completed. However what is critical is for the load cell to be bolted in place through the load cell center bolt hole anchoring the load cell in place and then be able to measure the subsequent weight put on top of the bolt (range of 0 to 1000 lbs), starting at zero measurement.
The next requirement is for a wireless signal to be sent to a digital screen showing what the measurement of weight is that was introduced on top of the bolt, preferably to the nearest 1 lb. or up to 5 lbs. (about 2%).
The load cell would be exposed to the environment and the digital receiver would not. The receiver would normally be located within 30 feet of the load cell.
Certification is not required.
Another option would be that the load cell would not be wireless, and the digital screen would be located adjacent, or close proximity, to the load cell and connected by wires.
The size of the load cell washer could be approximately 1.5 to 2 inches O.D. with a 3/4 inch diameter hole in it’s center, and 1/16 to 3/8 inch thick. And the digital receiver could be approximately 1 to 1.5 inches wide by 1 to 3 inches long and about ¼ to 3/8 inches thick, and a male/female Velcro type anchoring system on the back of it’s plastic housing, to keep it in place.
If this device proves to be marketable it would be ordered and mass produced in lots of 1000.
I am quite sure the device can be manufactured, it’s marketability will depend on how cheaply it can be done. The cost of the load cell will be critical. It should be priced as a volume product.
