Loosing solutions in a trig equation
  • Thread starter Appleton
  • Tags
    Trig
In summary, when solving equations, it is important to consider all possible values for the variable and not make assumptions that eliminate potential solutions, such as dividing by a function that may be equal to zero.
Appleton
91
find the values of x between 0 and 360
sin2x + cosx = 0
sin2x + cosx = 0
2sinxcosx = -cosx
2sinx = -1
sinx = -1/2
x = 210, 330
I'm guessing I lost the other solutions when I divided cosx by itself
sin2x + cosx = 0
sin2x + cosx = 0
2sinxcosx = -cosx
2sinx = -1
sinx = -1/2
x = 210, 330
Yes, you did. By dividing by cosx you assumed that cosx was never zero. In general, only cancel on both sides if you have a constant, independent of x.
sin2x + cosx = 0
sin2x + cosx = 0
2sinxcosx = -cosx
##\cos x(2\sin x + 1) = 0## Deal with both factors.
That is actually what he did, but he writes it differently, and he divides by [itex]\cos x[/itex] (oops.)
Basically, when you divide both sides of an equation by a function, you implicitly assume it is a nonzero function. For example, dividing both sides of an equation by [itex]a^x[/itex] when [itex]a\neq 0[/itex] is perfectly doable, because exponential functions are nonzero. However, a function like cosine has infinitely many zeroes, so you can't simply divide by cosine and forget about it.
You already solved half of the equation. But there are more solutions, and they are the zeroes of cosine in the interval given to you.
Thanks for your responses. So the other solutions within the given range are 90 and 270?
What is the strategy for 1) making sure you have all the solutions? 2) finding those more illusive solutions?
Yes, those are the solutions.
From your questions, I understand that you didn't get what we are trying to tell you. Consider this rather simple example: [itex]x^2 + x = 0[/itex].
Your erroneous way of solving this equation would be: Divide both sides by x so that you are left with [itex]x + 1 = 0[/itex], and hence [itex]x = -1[/itex]. That is one of the roots, but you can't obtain the second one [itex]x=0[/itex]. The reason for this is you assume x is not 0 when dividing by it, so if you want to do this the division way, the correct solution is this:
"Assume x is not 0. Then, we can divide by x and obtain [itex]x+1=0[/itex], which means we have one root -1. Now, assume x is 0. The equation is satisfied, and hence 0 is the second root."
There is also another way that might be less prone to confusion, suggested by LCKurtz. Factoring the example equation I provided, you get [itex]x(x+1) = 0[/itex]. If the product of two things equals 0, one of them must be 0. Equating x and x+1 to 0, you get the two roots 0 and -1. Note that there is no division in this solution. If the above logic about dividing by zero is confusing for you, the factoring way of doing it might be easier for you, as you don't have to worry about any divisions by zero.
You're right, I didn't get it, but I do now, thanks for clearing that up for me.
Related to Loosing solutions in a trig equation
1. What is a "loosing solution" in a trigonometric equation?
A "loosing solution" in a trigonometric equation refers to a solution that is not considered to be a part of the principal solution set. These solutions may exist due to the periodic nature of trigonometric functions, resulting in multiple solutions to a single equation.
2. How do I identify loosing solutions in a trigonometric equation?
To identify loosing solutions in a trigonometric equation, you can graph the equation or use a calculator to plot the function. The loosing solutions will appear as additional intersections on the graph, outside of the principal solution set.
3. Why are loosing solutions important in trigonometry?
Loosing solutions are important in trigonometry because they provide a more complete understanding of the behavior and patterns of trigonometric functions. They can also help us to better visualize and interpret solutions to equations in real-world applications.
4. How do I solve for loosing solutions in a trigonometric equation?
Solving for loosing solutions in a trigonometric equation involves finding all possible solutions to the equation, including those outside of the principal solution set. This can be done by using the unit circle, applying trigonometric identities, or using a calculator to find all solutions within a given interval.
5. Can loosing solutions be negative or complex numbers?
Yes, loosing solutions can be negative or complex numbers. This is because trigonometric functions can have multiple solutions, including negative and complex solutions, due to their periodic nature. It is important to consider all possible solutions when solving trigonometric equations.
34K
9K
