Lorentz covariance + Open string
In summary: Open strings are bosonic if they describe only bosonic excitations, while open strings that include fermionic excitations are called superstrings. Closed strings can also be either bosonic or super, depending on the types of excitations they describe.
wam_mi
81
Hi there,
Can I ask
(i) Is Lorentz covariance the same thing as Lorentz invariance? They seem to appear everywhere whenever we talk about space-time coordinates... what is the difference?
(ii) Is an open string the same as a bosonic string? Do bosons only appear as open strings or as closed strings? Sorry I'm confused!
Thanks!
1. Invariant objects are just that: invariant. In order to be invariant, they must have no free indices; that is, they must be scalars.
Covariant objects, on the other hand, have free indices. They are not invariant under Lorentz transformations, but rather, they transform in a specific way
[tex]A_{\mu'} = {L^{\mu}}_{\mu'} A_{\mu}[/tex]
Invariant objects can be built out of covariant objects by contracting all available indices:
[tex]\epsilon^{abcd} F_{ae} A^e S_{bcf} T^f_d[/tex]
This one is invariant...not sure if it's ever useful, though. :)
Note that some objects that have indices are not covariant; for example, the Christoffel symbols [itex]\Gamma^{\mu}_{\nu\sigma}[/tex]. Also, objects built out of non-covariant objects by contracting all indices are not generally Lorentz scalars...you have to check using the transformation rule of whatever objects you're contracting.
2. No. Bosonic strings may be either open or closed. Superstrings may also be open or closed. Open just means the string has endpoints, as opposed to closed strings which form loops.
Hi there!
To answer your questions:
(i) Yes, Lorentz covariance and Lorentz invariance are essentially the same thing. They both refer to the idea that the laws of physics should appear the same in all inertial reference frames, regardless of their relative motion. This is a fundamental principle in special relativity and is closely related to the concept of space-time coordinates.
(ii) An open string is a type of string in string theory that has two endpoints, while a closed string is a string that is connected at both ends to form a loop. So, an open string and a bosonic string are not the same thing. A bosonic string can be either open or closed, while a fermionic string can only be closed. Bosons and fermions are both types of particles, and they can appear in both open and closed strings. However, in string theory, the most commonly studied strings are bosonic, which is why you may see them referred to as "open strings."
I hope this helps clarify things for you! Let me know if you have any other questions.
Related to Lorentz covariance + Open string
1. What is Lorentz covariance?
Lorentz covariance is a fundamental principle in the theory of special relativity, which states that the laws of physics should appear the same for all observers in uniform motion. This means that the laws of physics should not change when viewed from different inertial frames of reference, even if these frames are moving at different velocities.
2. How does Lorentz covariance relate to open strings?
Lorentz covariance is a key concept in the theory of open strings, which are one-dimensional objects that vibrate in space-time. The equations that describe the motion of open strings must be invariant under Lorentz transformations, meaning that they should produce the same results when viewed from different reference frames. This is necessary for the consistency of the theory and to ensure that the laws of physics hold true for all observers.
3. Why is Lorentz covariance important in the study of open strings?
Lorentz covariance is important in the study of open strings because it ensures that the theory is consistent with the principles of special relativity. This allows for the development of a unified theory that can accurately describe the behavior of open strings in all reference frames, regardless of their relative velocities.
4. Can Lorentz covariance be violated in the theory of open strings?
No, Lorentz covariance cannot be violated in the theory of open strings. This principle is a fundamental requirement for any theory that aims to describe the behavior of objects in space-time, and any violation would lead to inconsistencies and contradictions within the theory.
5. How is Lorentz covariance tested in the study of open strings?
Lorentz covariance can be tested in the study of open strings through various experiments and observations. For example, the behavior of open strings can be measured and compared in different reference frames to see if the results are consistent with the principles of special relativity. Additionally, theoretical predictions based on Lorentz covariance can be tested against experimental data to validate the theory.
  • Beyond the Standard Models
11K
