Lorentz Force & Newton's 3rd Law
In summary, the Lorentz force is the interaction of a moving charge in a magnetic field. The force only exists due to the conservation of momentum and the symmetrical nature of the interaction.
ElectricJosh
Hello,
I have been wondering this for a while and have only recently thought to ask here.
The Lorentz force is the interaction of a moving charge in a magnetic field, it doesn't seem to have any sort of physical force applied to it, only the magnetic interaction.
I was wondering, if there is a force being generated by the field on the moving charge, then where is the equal and opposite force as stated in Newtons 3rd law or does it not have one?
Thank you very much.
It is important not to mix up models, in this case the force and interaction picture seems to have got mixed up.
Force picture:
- a moving charge experiences a force from the electromagnetic field.
The reaction force is experienced by whatever generated the field... i.e. another charge.
We don't always deal with that for the same reason we don't always bother with the reaction of the Earth to, say, a bouncing ball.
Interaction picture:
- a moving charge experiences an electromagnetic interaction.
... this is a different model. To get an interaction, it must absorb or emit a virtual photon.
The concept of "force" is not invoked as part of the model here, only conservation and symmetry arguments.
So discussion of forces in this model is irrelevant.
However, we can ask how the appearance of the third law comes about from fundamental interactions - which is, I suspect, where you are headed.
It happens due to the photon interaction involving two charged bodies - one loses the photon and the other gains it.
Newton's laws of motion are an emergent phenomena arsing from many fundamental interactions - they only work on average.
Newton's third law doesn't apply to fields. However, it does generalize to the conservation of momentum, which applies to fields. The change in the momentum of the charge is associated with an equal and opposite change in the momentum of the field.
Likes GiuseppeR7
Hey Guys, thanks for responding.
Conservation of momentum is what I was primarily concerned about.
So there is a reaction force that acts on the object that generated the field.
The two charges example makes sense, but where would the reaction force act on a magnetic field generated by a coil of wire?
The electron charges are spinning in the coils which generates the magnetic field, when the field interacts with another charge outside the coils, does the reaction force try and stretch the coil radius outwards in all directions?
Thank you kindly.
com of coil.
Related to Lorentz Force & Newton's 3rd Law
What is the Lorentz Force?
The Lorentz Force is the force experienced by a charged particle when it is placed in an electric and magnetic field. It follows the cross-product formula F = q(E + v x B), where q is the charge, E is the electric field, v is the velocity of the particle, and B is the magnetic field.
What is Newton's 3rd Law?
Newton's 3rd Law states that for every action, there is an equal and opposite reaction. This means that when two objects interact, they exert equal and opposite forces on each other.
How are Lorentz Force and Newton's 3rd Law related?
The Lorentz Force is a manifestation of Newton's 3rd Law. When a charged particle experiences a force due to an electric and magnetic field, it also exerts a force back on the fields. This force is equal in magnitude and opposite in direction, as stated by Newton's 3rd Law.
Can Lorentz Force and Newton's 3rd Law be applied to any situation?
Yes, Lorentz Force and Newton's 3rd Law can be applied to any situation where there is an interaction between charged particles and electric and magnetic fields. These principles are fundamental to understanding the behavior of electricity and magnetism.
How does the direction of the Lorentz Force relate to the direction of the magnetic field?
The direction of the Lorentz Force is perpendicular to both the direction of the charged particle's velocity and the direction of the magnetic field. This can be determined using the right-hand rule, where the thumb points in the direction of the particle's velocity, the fingers point in the direction of the magnetic field, and the palm indicates the direction of the force.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
