Lorentz scalars - transformation of a scalar field
In summary, a Lorentz transformation between two frames ##S## and ##S'## results in a scalar field ##\phi (x)## transforming as ##\phi '(x')=\phi (x)## or ##\phi '(x)=\phi (\Lambda^{-1}x)##, making it a Lorentz invariant quantity. When transforming coordinates from ##S## to ##S'##, the field has a different functional form but retains the same numerical value at a given point ##p##. This means that while the coordinates may change, the physical values do not.
"Don't panic!"
601
When one considers a Lorentz transformation between two frames ##S## and ##S'##, such that the coordinates in ##S## are given by ##x^{\mu}## and the coordinates in ##S'## are given by ##x'^{\mu}##, with the two related by [tex]x'^{\mu}=\Lambda^{\mu}_{\;\;\nu}x^{\nu}[/tex] then a scalar field ##\phi (x)## relative to ##S## transforms as [tex]\phi '(x')=\phi (x)\qquad\text{or}\qquad\phi '(x)=\phi (\Lambda^{-1}x)[/tex] where ##\phi '(x')## is the form of the scalar field relative to the frame ##S'##. Clearly, as it is a scalar it is a Lorentz invariant quantity.
My question (albeit a simple one, so apologies for that) is, when we transform the coordinates from those defined in ##S## to those defined in ##S'## (i.e. ##x\rightarrow x'##), am I understanding it correctly that the field transforms as ##\phi\rightarrow\phi '##, such that it has a different functional form in the two different frames, ##S## and ##S'##, but in such a way that when evaluated at a given point ##p##, then it has the same value in both frames? (That is, if a point ##p## has coordinates ##x^{\mu}## in ##S## and coordinates ##x'^{\mu}## in ##S'## then ##\phi '(x')=\phi (x)##, however, the functional form of ##\phi## will be different to the functional form of ##\phi '##)
"Don't panic!" said:
am I understanding it correctly that the field transforms as ##\phi\rightarrow\phi'##, such that it has a different functional form in the two different frames, ##S## and ##S'##, but in such a way that when evaluated at a given point ##p##, then it has the same value in both frames? (That is, if a point ##p## has coordinates ##x^{\mu}## in ##S## and coordinates ##x'^{\mu}## in ##S'## then ##\phi '(x')=\phi (x)##, however, the functional form of ##\phi## will be different to the functional form of ##\phi'##)
Yes, this is how it works. Another way to put it is that the point ##p##, physically, is identified by the value of physical quantities there, such as ##\phi##; its coordinates may change but the physical values do not.
Likes vanhees71
PeterDonis said:
Yes, this is how it works. Another way to put it is that the point pp, physically, is identified by the value of physical quantities there, such as ϕ\phi; its coordinates may change but the physical values do not.
Ok great, thanks for confirming this. Is what I put about ##\phi## and ##\phi '## being different functional forms of the scalar field (relative to the two different reference frames ##S## and ##S'## respectively), but having the same numerical value at each point correct?
Yes.
OK, great. Thanks for your help! ☺
Related to Lorentz scalars - transformation of a scalar field
1. What is a Lorentz scalar?
A Lorentz scalar is a physical quantity that remains unchanged under Lorentz transformations, which are transformations that describe how measurements of space and time change between two reference frames moving at constant velocities relative to each other.
2. What is a scalar field?
A scalar field is a function that assigns a scalar value to every point in space. It can represent various physical quantities such as temperature or energy density.
3. How does a Lorentz scalar transform under a Lorentz transformation?
A Lorentz scalar transforms the same way as a regular scalar under Lorentz transformations. This means that the value of the scalar remains unchanged, regardless of the reference frame in which it is measured.
4. What is the significance of Lorentz scalars in physics?
Lorentz scalars are important in physics because they provide a way to describe physical quantities that are independent of the observer's reference frame. This is essential in understanding the fundamental laws of physics, such as the theory of relativity.
5. Can a scalar field be a Lorentz vector or tensor?
No, a scalar field cannot be a Lorentz vector or tensor because it only has a single value at each point in space, while vectors and tensors have multiple components. However, a scalar field can be used to construct Lorentz vectors and tensors by taking derivatives or gradients of the field.
  • Classical Physics
