Lorentz Time Transformation Problem
In summary, the observer aboard the spacecraft would see the transit starting at the same time as the earthbound observer, but it would appear to be happening 38.268 years away from their perspective due to the effects of time dilation and length contraction.
Vorde
788
1) An alien spacecraft flies past the Earth with a speed of 0.866 c., according to an earthbound observer. One year later that observer witnesses a newly discovered planet start to pass between the Earth and its star (an event known as a transit) 20 ly away. When and where would an observer aboard the ship say the transit started?
x=20 ly
t=1 y
v= .866 c
t'= (t-(vx/c))/(root(1-(v/c)^2)
(Sorry, the math notation wouldn't work, anyways it's the Lorentz transformation for time).
Plug in: (20-(.866*1/1))/(root(1-(.866/1)^2)
Solve.
t'= 38.268 years
The problem is that this seems to say that an object speeding towards an event would see the event after the observer farther away (38.268 years rather than 20 years), which even in the context of special relativity doesn't make sense to me?
Can anyone help me out here?
As an observer on the spacecraft, you would see the transit starting at the same time as the earthbound observer, but the transit would appear to be happening 38.268 years away from your perspective. This is due to time dilation and length contraction effects caused by the high speed of the spacecraft. Essentially, time would appear to be passing slower for you and distances would appear to be shorter, compared to the earthbound observer. So while the transit would appear to be happening 20 light years away from the earthbound observer, it would appear to be happening 38.268 light years away from you on the spacecraft. This is a result of the relativity of simultaneity, which states that events that are simultaneous for one observer may not be simultaneous for another observer in a different frame of reference.
FAQ: Lorentz Time Transformation Problem
What is the Lorentz Time Transformation Problem?
The Lorentz Time Transformation Problem is a concept in special relativity that deals with the difference in time measurements between two frames of reference moving at different velocities. It is based on the principles of time dilation and length contraction, and helps to explain how time is perceived differently by observers in different frames of reference.
How is the Lorentz Time Transformation Problem derived?
The Lorentz Time Transformation Problem is derived from the Lorentz transformation equations, which were first proposed by physicist Hendrik Lorentz in 1904. These equations describe how space and time measurements change between two frames of reference moving at different velocities, and form the foundation of Einstein's theory of special relativity.
What is the significance of the Lorentz Time Transformation Problem?
The Lorentz Time Transformation Problem is significant because it helps to reconcile the apparent discrepancies between classical mechanics and the theory of relativity. It also demonstrates the concept of time dilation, which is crucial in understanding the behavior of objects moving at high speeds and the nature of space-time.
Can the Lorentz Time Transformation Problem be applied to everyday situations?
While the Lorentz Time Transformation Problem is often used in theoretical physics and in understanding the behavior of particles at high speeds, it can also be applied to everyday situations. For example, the GPS system used for navigation relies on the principles of the Lorentz Time Transformation Problem to accurately determine time and location.
Are there any limitations to the Lorentz Time Transformation Problem?
Like any scientific theory, the Lorentz Time Transformation Problem has its limitations. It is only applicable to objects moving at constant velocities and does not take into account the effects of acceleration. It also does not apply to objects moving at speeds close to the speed of light, where the effects of time dilation become more significant.
