Lorentz Transformation in One-Dimensional Space
In summary, the conversation discusses the possibility of a one-dimensional space and its implications for Einstein's theory of relativity. While it is possible to demonstrate the relativity of simultaneity in one dimension, the Lorentz transformation still requires at least a second dimension for the Lorentz factor to be obtained. The concept of light cone is also discussed, with the equation c^2dt^2=dx^2+dy^2+dz^2 being reduced to cdt=dx. However, it is pointed out that this equation still involves the square roots of squares. The conversation ends with the mention of a one-dimensional derivation by Einstein in his book "Relativity: The special and general theory".
the_emi_guy
766
79
If space only had one dimension would Einstein's speed of light postulate still lead to Lorentz transformation for motion along that one dimension?
Relativity of simultaneity can obviously be demonstrated in one dimension (lightning bolts hitting opposite ends of stationary and moving train). But all derivations of the Lorentz transformation seem to require at least a second space dimension (i.e. the familiar light clock and Einsteins original 1905 paper) in order to obtain the Lorentz factor. Also, description of light cone:
c2dt2=dx2+dy2+dz2 reduces to
cdt=dx so space-time intervals would no longer have the square roots of squares involved.
It's easy to do a one-dimensional derivation; there's one by Einstein in the appendix of his book "Relativity: The special and general theory".
Basically we're looking for coordinate transformations such that ##x\pm{c}t=0## implies ##x'\pm{c}t'=0##, which is to say the speed of light is ##c## in both frames.
Yes it would. You are missing one root by asserting c dt = dx.
Thanks, this is what I was looking for.
Then you are let even to a larger group of transformations, namely the whole conformel group!
Related to Lorentz Transformation in One-Dimensional Space
What is Lorentz Transformation in One-Dimensional Space?
Lorentz Transformation in One-Dimensional Space is a mathematical concept developed by Dutch physicist Hendrik Lorentz to describe the effects of time and space on objects moving at high speeds, specifically in the context of special relativity.
What is the purpose of Lorentz Transformation in One-Dimensional Space?
The purpose of Lorentz Transformation in One-Dimensional Space is to reconcile the differences between the laws of physics observed in different inertial frames of reference, specifically when objects are moving at high speeds close to the speed of light.
What are the key equations used in Lorentz Transformation in One-Dimensional Space?
The key equations used in Lorentz Transformation in One-Dimensional Space are the Lorentz transformations for time, length, and velocity. These equations involve the speed of light, the relative velocity between two frames of reference, and the Lorentz factor, which takes into account the effects of time dilation and length contraction.
How does Lorentz Transformation in One-Dimensional Space differ from Galilean Transformation?
Lorentz Transformation in One-Dimensional Space differs from Galilean Transformation in that it takes into account the principles of special relativity, including the constancy of the speed of light and the relativity of simultaneity. Galilean Transformation, on the other hand, is based on the classical Newtonian principles of absolute time and space.
What are the practical applications of Lorentz Transformation in One-Dimensional Space?
The practical applications of Lorentz Transformation in One-Dimensional Space include GPS systems, particle accelerators, and high-speed transportation technology, as well as understanding the behavior of objects moving at high speeds and predicting the effects of time dilation and length contraction in these scenarios.
