Lorentz transformation of infinitesimal boost and rotation?
In summary, the Lorentz transformation of infinitesimal boosts and rotations describes how space and time coordinates change under small velocity transformations and rotations in the framework of special relativity. The transformation can be expressed mathematically, showing how an observer moving with a small velocity relative to another observer measures different time and spatial coordinates. This framework preserves the constancy of the speed of light and the form of physical laws across different inertial frames, highlighting the intertwined nature of space and time in relativistic physics.
jag
1. Show that the infinitesimal boost by v_j along the x_j axis is given by the Lorentz transformation (see attempted solution)
2. Show that infinitesimal rotation by theta_j by x_j is given by (see attempted solution)
Explained in attempted solution
1. Show that the infinitesimal boost by ##v^j## along the ##x^j##-axis is given by the Lorentz transformation
$$\Lambda_{\nu}^{\mu} = \begin{pmatrix}
1 & v^1 & v^2 & v^3 \\
v^1 & 1 & 0 & 0 \\
v^2 & 0 & 1 & 0 \\
v^3 & 0 & 0 & 1 \\
\end{pmatrix}$$
Attempted solution
I know that for x-axis
\gamma^1 & \beta^1\gamma^1 & 0 & 0 \\
\beta^1\gamma^1 & \gamma^1 & 0 & 0 \\
0 & 0 & 1 & 0 \\
0 & 0 & 0 & 1 \\
\end{pmatrix}$$
Replacing ##\gamma = \frac{1}{\sqrt{1-\frac{v^2}{c^2}}}## and ##\beta = \frac{v}{c}## and setting ##c = 1## with ##v \ll c##, I can get the following for the x-axis
1 & v^1 & 0 & 0 \\
v^1 & 1 & 0 & 0 \\
0 & 0 & 1 & 0 \\
0 & 0 & 0 & 1 \\
\end{pmatrix}$$
Similarly, I am constructing the y-axis Lorentz transformation
1 & 0 & v^2 & 0 \\
0 & 1 & 0 & 0 \\
v^2 & 0 & 1 & 0 \\
0 & 0 & 0 & 1 \\
\end{pmatrix}$$
and z-axis Lorentz transformation
1 & 0 & 0 & v_3 \\
0 & 1 & 0 & 0 \\
0 & 0 & 1 & 0 \\
v^3 & 0 & 0 & 1 \\
\end{pmatrix}$$
Then, I'm thinking of adding together the matrices but it doesn't yield the final answer, so I'm stuck here. Any pointers will be helpful.
2. Show that infinitesimal rotation by ##\theta^j## about ##x^j## is given by
1 & 0 & 0 & 0 \\
0 & 1 & \theta^3 & -\theta^2 \\
0 & -\theta^3 & 1 & \theta^1 \\
0 & \theta^2 & -\theta^1 & 1 \\
\end{pmatrix}$$
Attempted solution
I'm reading through https://en.wikipedia.org/wiki/Rotation_matrix but as far I can understand rotation matrix are presented in ##\cos## and ##\sin##, so I'm not sure how to proceed here.
Looking forward to any assistance.
adding? not multiplying?
@anuttarasammyak Sorry, I meant to write multiplying in the post.
I haven't worked out the details myself so I apologize if I'm wrong (I'm addressing question number 1)
but usually a transformation matrix is constructed by projecting the old vectors onto the new vectors and arranging it in a matrix
that can be done via the dot product in usually euclidean space
but in minkowski space
you need to use "the metric" in order to do that. Use the appropriate signature.
For question number (1), I multiplied the Lorentz transformation matrix for each axis and I get the result
v^1 & 1 & v^1v^2 & v^1v^3 \\
v^2 & 0 & 1 & v^2v^3 \\
v^3 & 0 & 0 & 1 \\
\end{pmatrix}$$
My assumption is ##v_iv_j = 0## and hence, yielding the answer. I'm not sure whether this assumption is right.
Did you use the fact that it's an infinitesimal boost?
jag said:
I'm reading through https://en.wikipedia.org/wiki/Rotation_matrix but as far I can understand rotation matrix are presented in cos and sin, so I'm not sure how to proceed here.
Apply usual rotation matrices and substitute ##\cos\theta\approx 1##, ##\sin\theta\approx \theta## neglecting second and higher order infinitesimals.
jag said:
Homework Statement: 1. Show that the infinitesimal boost by v_j along the x_j axis is given by the Lorentz transformation (see attempted solution)
Relevant Equations: Explained in attempted solution
v^1 & 1 & 0 & 0 \\
v^2 & 0 & 1 & 0 \\
v^3 & 0 & 0 & 1 \\
\end{pmatrix}$$
Attempted solution
0 & 0 & 1 & 0 \\
0 & 0 & 0 & 1 \\
\end{pmatrix}$$
1 & v^1 & 0 & 0 \\
v^1 & 1 & 0 & 0 \\
0 & 0 & 1 & 0 \\
0 & 0 & 0 & 1 \\
\end{pmatrix}$$
1 & 0 & v^2 & 0 \\
0 & 1 & 0 & 0 \\
v^2 & 0 & 1 & 0 \\
0 & 0 & 0 & 1 \\
\end{pmatrix}$$
1 & 0 & 0 & v_3 \\
0 & 1 & 0 & 0 \\
0 & 0 & 1 & 0 \\
v^3 & 0 & 0 & 1 \\
\end{pmatrix}$$
1 & 0 & 0 & 0 \\
\end{pmatrix}$$
Attempted solution
To get from a Lie-group element, e.g., a rotation around a fixed axis to a Lie-algebra element you have to expand the Lie-group element in powers of the parameter (here the rotation angle) up to first order in the parameter. Just write down a rotation matrix around, e.g., the 3-axis and expand the cos and sin functions appearing there. Then write the result in a manifestly covariant way, and you get it for an arbitrary direction of the rotation axis or use the same arguments as for the Lorentz boosts.
Hi All, it is super clear for me now. Thank you very much for your help! As a self-learner of physics, this forum has been really helpful for me! :smile:
Likes vanhees71
FAQ: Lorentz transformation of infinitesimal boost and rotation?
What is the Lorentz transformation for an infinitesimal boost?
The Lorentz transformation for an infinitesimal boost in the x-direction can be written as:\[ \Lambda^\mu_{\ \nu} = \delta^\mu_{\ \nu} + \omega^\mu_{\ \nu} \]where \(\omega^\mu_{\ \nu}\) is the infinitesimal boost generator. For a boost in the x-direction, it is given by:\[ \omega^\mu_{\ \nu} = \begin{pmatrix}0 & \epsilon & 0 & 0 \\\epsilon & 0 & 0 & 0 \\0 & 0 & 0 & 0 \\0 & 0 & 0 & 0\end{pmatrix} \]where \(\epsilon\) is a small parameter representing the boost velocity divided by the speed of light.
How does the Lorentz transformation change under an infinitesimal rotation?
For an infinitesimal rotation about the z-axis, the Lorentz transformation matrix is given by:\[ \Lambda^\mu_{\ \nu} = \delta^\mu_{\ \nu} + \omega^\mu_{\ \nu} \]where \(\omega^\mu_{\ \nu}\) is the infinitesimal rotation generator. For a rotation about the z-axis, it is:\[ \omega^\mu_{\ \nu} = \begin{pmatrix}0 & 0 & 0 & 0 \\0 & 0 & -\theta & 0 \\0 & \theta & 0 & 0 \\0 & 0 & 0 & 0\end{pmatrix} \]where \(\theta\) is a small angle representing the rotation.
What is the significance of the infinitesimal Lorentz transformation?
The significance of the infinitesimal Lorentz transformation lies in its ability to describe small changes in the reference frame. These small transformations can be used to build up finite Lorentz transformations through exponentiation. Infinitesimal transformations are also essential in the study of Lie algebras and the representation theory of the Lorentz group.
How are the generators of infinitesimal boosts and rotations related to the Lorentz algebra?
The generators of infinitesimal boosts and rotations form the basis of the Lorentz algebra. The Lorentz algebra is characterized by the commutation relations between these generators. For example, the generators of boosts \(K_i\) and rotations \(J_i\) satisfy the following commutation relations:\[ [J_i, J_j] = i\epsilon_{ijk}J_k \]\[ [J_i, K_j] = i\epsilon_{ijk}K_k \]\[ [K_i, K
