Lorentz Transformation, Time Dilation, Length Contraction
In summary: In the rocket frame, the distance between the Earth and the sun is 4.8 light-minutes, and the Earth is traveling toward the ship at 0.8c, what should the answer to d be?c) is just 10 minutes - 8 light minutes = 2 minutes?
Kunhee
51
[/B]
A spaceship is approaching Earth from the far side of the sun. The Earth and sun are 8 light minutes apart and the ship is traveling at .8c. Two events are indisputable. 1) the ship is at the sun 2) the ship is at the earth. Assume that the Earth and sun are at rest according to each other. The ship is detectable only after it passes the sun.
a) In the Earth's frame, how much time separates events 1 and 2?
b) In the Earth's frame, how much distance separates events 1 and 2?
c) How much time after first detecting the ship do humans on Earth have to prepare for its arrival?
d) In the ship's frame, how much time separates events 1 and 2?
e) In the ship's frame, how much distance separates events 1 and 2?
f) In the ship's frame, how far apart are Earth and sun?
The Lorentz factor is 5/3 when we plug in .8c. I am having trouble setting up the problem.
What is the difference between a and c? Or e and f?
a) the time that separates the two events is simply t = d/v = 8c/.8c = 10 minutes
b) the distance that separates the two events is simply 8c = 8 light minutes.
c) Earth has 10 minutes to prepare for the ship's arrival.
d) t' = (5/3)(10) = 16.67 minutes
e) x' = (3/5)(8c) = 4.8 light minutes
f) Earth and Sun are 4.8 light minutes apart
I have trouble understanding your answers. Can you give the numerical answers in minutes and in light-minutes for parts a and b?
For a, I did time dilation T' = (5/3)(To) where To is 8c/.8c just from t = d/v
T' = (5/3)(To)
T' = (5/3)(8c/.8c)
T' = (5/3)(10) = 16.67 minutes
For b, I did length contraction L' = (3/5)(Lo) where Lo is 8c
L' = (3/5)(8c)
L' = 4.8 light minutes
The Earth is at rest and the two events are Earth x1, = 0 and Sun, x2 = 8c. So when the question asks for time that separates these events in Earth's frame, it must mean how much dilated time it takes for the ship to get from x2 to x1. And when the question asks for the distance, it is asking for the contracted length?
Or because the Earth is at rest, none of this applies...?
I am a bit confused.
Since the Earth and sun are at rest, and since the distance 8 light-minutes and the velocity 0.8c applies to this frame, you are correct in concluding that none of this Lorentz stuff applies.
I see. Thank you for the clarification.
So what is the difference between questions a and c? Or e and f?
The answer to c should be 2 minutes.
The answer to e is not correct. Event 1 occurs at the same coordinate in the rocket frame (the nose of the ship) as Event 2 (the nose of the ship). So, in the rocket frame, what is the distance between the two events? Answer f is correct. Now, if, in the ship frame, the distance between the Earth and the sun is 4.8 light-minutes, and the Earth is traveling toward the ship at 0.8c, what should the answer to d be?
This part is a bit confusing to me how it translates to how much time people have
after seeing event 2 until event 1 occurs.
e) the distance between the two events in the rocket frame is just 8 light minutes.
f) is therefore using 8c for length contraction so x' = (3/5)(8c) = 4.8 light minutes
d) is then t = d/v = 4.8c / .8c = 6 minutes
Events 1 and 2 occur at the same location in the ship frame of reference. So the answer to.e is zero distance.
Could you explain why c is 2 minutes?
Once the ship emerges from behind the sun, it takes 8 minutes for the light to reach the earth. It takes 10 minutes for the ship to reach the earth. So the people first see the ship two minutes before it arrives.
Likes Kunhee
Ah I see. Thank you for the help!
Related to Lorentz Transformation, Time Dilation, Length Contraction
1. What is the Lorentz Transformation?
The Lorentz Transformation is a mathematical formula that describes how the measurements of time and space change between two frames of reference that are moving relative to each other. It is a fundamental concept in Einstein's theory of Special Relativity.
2. What is Time Dilation?
Time Dilation is a phenomenon in which time appears to pass slower for an object that is moving at high speeds, relative to an observer that is at rest. This is a direct consequence of the Lorentz Transformation and is one of the key principles of Special Relativity.
3. How does Length Contraction occur?
Length Contraction is the decrease in the measured length of an object that is moving at high speeds, relative to an observer that is at rest. This is also a consequence of the Lorentz Transformation and is a result of the relativity of simultaneity - the idea that events that are simultaneous for one observer may not be simultaneous for another observer.
4. Can these concepts be observed in everyday life?
Yes, the effects of Lorentz Transformation, Time Dilation, and Length Contraction are observed in everyday life, although they become more significant at extremely high speeds. For example, GPS satellites have to account for the effects of time dilation in order to provide accurate location data on Earth.
5. How do these concepts affect our understanding of space and time?
The concepts of Lorentz Transformation, Time Dilation, and Length Contraction challenge our traditional understanding of space and time as absolute and unchanging. They demonstrate that space and time are relative and can be influenced by the motion of an observer. This has significant implications for our understanding of the universe and has led to the development of the theory of General Relativity.
