Lorentz-Transforming a Newton-Wigner State
  • Thread starter l-ame
  • Tags
    State
In summary, Mourad's paper discusses the de-localization of a Newton Wigner state due to a Lorentz transformation, but does not show how to calculate the integral.
l-ame
Hello
I recently stumbled upon an article about Newton Wigner states (cf 10.1103/RevModPhys.21.400). It is repeatedly mentioned in the literature that acting with a Lorentz transformation on a Newton Wigner state completely delocalizes the state. However I was not able to verify this, albeit I found an article by J. Mourad (arXiv:gr-qc/9310018v1), which deals with exactly this question.
The Newton Wigner eigenstates are given by
[tex]\psi (x) = \sqrt{\omega (\vec{p})} e^{-i\vec{p}\cdot\vec{q_0}[/tex]
(a state localized at position [tex]q_0[/tex] at a time t).
Then the transformed state can be written as (in a basis [tex]{|\vec{q}\rangle}[/tex] of Newton Wigner eigenstates)
[tex]\langle \vec{q} | \psi '\rangle = \int \frac{d^3p}{(2\pi)^{3/2}\omega} \langle \vec{q}|\vec{p}\rangle \langle{\vec{p}|\psi '\rangle[/tex]
where [tex]\psi'[/tex] denotes the Lorentz transformed state. The integral measure has a factor of [tex]\omega[/tex] in the denominator in order to be Lorentz invariant and [tex]\langle \vec{q}|\vec{p}\rangle = (2\pi)^{-3/2} e^{i\vec{p}\cdot\vec{q}}[/tex].
Unfortunately I do not succeed in evaluating the last inner product.
The whole integral in Mourad reads
[tex]\langle \vec{q} | \psi '\rangle = \sqrt{\gamma} \int \frac{d^3p}{(2\pi)^{3}} \sqrt{\left(1-\frac{\vec{\beta}\cdot\vec{p}}{\omega}\right)}e^{i\vec{p}\cdot (\vec{q}-\vec{q_0'})}[/tex]
where [tex]\gamma^2 = 1-\beta^2[/tex].
Any help would be highly appreciated :). Thanks
Hi l-ame,
welcome to the Forum!
I haven't seen these kinds of integrals evaluated explicitly. The usual argument for the de-localization in the moving frame is the qualitative statement given also in the Mourad's paper:
"The function (3.4) cannot vanish outside a bounded domain because it is the Fourier transform of a non-analytic function. This is due to the presence of square roots in the integrand."
A similar argument is used to justify the "superlumial spreading of wave packets", i.e., de-localization due to time translation. See works by Hegerfeldt and others.
Eugene.
Hi Eugene
Thanks for your reply.
Unfortunately I already struggle with the derivation of formula 3.4 in Mourad's paper. I can't see where the root in the integral is coming from?
In order to get the Lorentz transform of a wave function in the position space you need to perform three steps:
1. Change to the momentum representation (Fourier transform)
2. Lorentz transform of the momentum-representation wave function.
3. Change back to the position representation (inverse Fourier transform).
The step 2. can be found in eq. (2.5.23) of S. Weinberg, "The quantum theory of fields", vol. 1. This eq. shows the appearance of the square root. Note also that Mourad and Weinberg use different normalization (scalar product) conventions. In Weinberg's book momentum eigenfunctions are normalized to delta function (2.5.19). In Mourad's paper the scalar product is given by (3.2). I am in favor of the Weinberg's approach. You can find the application of this approach to the de-localization in moving frames in subsection 11.1.2 of http://www.arxiv.org/abs/physics/0504062v12
Eugene.
Great! Thank you so much for your help.
l-ame
FAQ: Lorentz-Transforming a Newton-Wigner State
What is Lorentz Transformation?
Lorentz Transformation is a mathematical equation used in physics to describe the relationship between space and time in the theory of special relativity. It was developed by Dutch physicist Hendrik Lorentz in the late 19th century and later refined by Albert Einstein.
What is a Newton-Wigner State?
A Newton-Wigner State is a quantum state that describes the position and momentum of a single particle in three-dimensional space. It is named after physicists Isaac Newton and Eugene Wigner, who independently proposed a way to describe the position and momentum of a particle in quantum mechanics.
How does Lorentz Transformation affect a Newton-Wigner State?
Lorentz Transformation alters the coordinates of a Newton-Wigner State in a way that maintains the same physical laws and properties. It takes into account the effects of time dilation and length contraction, which are consequences of special relativity.
Why is it important to Lorentz-Transform a Newton-Wigner State?
Lorentz-Transforming a Newton-Wigner State is important because it allows us to understand the behavior of particles at high speeds, close to the speed of light. It also helps us to reconcile the laws of mechanics with the laws of electromagnetism, which were previously believed to be separate.
Are there any limitations to Lorentz-Transforming a Newton-Wigner State?
Yes, Lorentz-Transforming a Newton-Wigner State is only applicable in the theory of special relativity and cannot be used to describe the behavior of particles in the theory of general relativity. It also assumes that the laws of physics are the same, regardless of the observer's frame of reference.
