Lorentzian line profile of emitted radiation
The discussion revolves around the derivation of the Lorentzian line profile of emitted radiation, starting from a model of the atom as a harmonic oscillator. The key point is the transition from a monochromatic to a frequency-distributed emission due to the damping of oscillations, which involves a Fourier transformation of the oscillation function. A participant raises a question about the origin of a factor of 1/2 in the integral, suggesting it should be 2 due to symmetry in the amplitude function. The conversation emphasizes the importance of considering the real part of the Fourier transform and clarifies the treatment of negative frequencies and time in the derivation. Overall, the discussion highlights the complexities involved in understanding the mathematical representation of emitted radiation.
MigMRF
Explain the derivation of the lorentzian line profile. Use "Laser Spectroscopy 1" By Wolfgang Demtöder pp 76-78 as inspiration
Fourier transform, inverse fourier transform, solution to harmonic oscilator.
First of all i tried to follow the textbook. Here they start of by modelling the atom as an harmonic oscilator:
Then they find the solution as:
They neglect the second term as omega_0 >> gamma which also makes good sense so they end up with:
So far so good. After this they state the following:
Because the amplitude x.t/ of the oscillation decreases gradually, the frequency of
the emitted radiation is no longer monochromatic as it would be for an oscillation
with constant amplitude. Instead, it shows a frequency distribution related to the
function x(t) by a Fourier transformation-
The damped oscillation x(t) can be described as a superposition of monochromatic oscillations exp(i omega t) with slightly different frequencies omega and amplitudes A(omega).
I understand that a inverse fourier transform is going on here, so that we get away from the frequency domain. And the term 1/sqrt(2 pi) is the normalization constant, which also makes good sense. But where does the 1/2 factor come from? The integral goes from 0 to infinity, and as the amplitude is a symmetric function i would expect that we'd have to multiply by two when taking the integral over the half space, not divide.
It's been some hours of trying to figure out what is going on, but without any luck. Hope that some of you can help me out understanding this step in the derivation, as the rest of it seems pretty clear.
## A(\omega)=\int x(t) e^{-i \omega t} dt ## apart from a numerical constant. I didn't do the integral just now, but I remember doing it a couple years ago, and I think it should work. Try for ## t>0 ##, because of the damping term.
Use ##\cos(\omega_o t)=(e^{i \omega_o t}+e^{-i \omega_o t})/2 ##.
Edit: and perhaps a minor detail, but it might be a necessary one: ## x(t) ## is real, so you may need to include the negative ## \omega's ##, (and perhaps even negative ## t's ## to get it to work). You might need to write the damping term (the exponent) with a plus sign for ## t<0 ##.
I agree that the factor of 1/2 should be a factor of 2. But I also think that it should be specified that the real part of the right-hand side should be taken.
From ##A(\omega) = \frac {1}{\sqrt{2\pi}} \int_{-\infty}^\infty{x(t)e^{-i\omega t}} dt## and the fact that ##x(t)## is real, we must have ##A^*(\omega) = A(-\omega)##. So,
$$x(t) = \frac {1}{\sqrt{2\pi}} \int_{-\infty}^\infty{A(\omega)e^{i\omega t}} d\omega $$
$$= \frac {1}{\sqrt{2\pi}} \left(\int_{-\infty}^0{A(\omega)e^{i\omega t}} d\omega + \int_{0}^{\infty}{A(\omega)e^{i\omega t}} d\omega \right)$$
$$= \frac {1}{\sqrt{2\pi}} \left(\int_{0}^{\infty}{A(-\omega)e^{-i\omega t}} d\omega + \int_{0}^{\infty}{A(\omega)e^{i\omega t}} d\omega \right)$$
$$= \frac {1}{\sqrt{2\pi}} \left(\int_{0}^{\infty}{A^*(\omega)e^{-i\omega t}} d\omega + \int_{0}^{\infty}{A(\omega)e^{i\omega t}} d\omega \right)$$
$$= \frac {1}{\sqrt{2\pi}} \left(\int_{0}^{\infty}{A(\omega)e^{i\omega t}} d\omega +CC \right)$$
$$= \frac {2}{\sqrt{2\pi}} Re\left[ \int_{0}^{\infty}{A(\omega)e^{i\omega t}} d\omega \right]$$
Likes vanhees71 and Charles Link
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
