Loss of energy and energy loss prevention in circuits
In summary: AC power transmission over a long distance. Again, add graphs to represent voltage and current vs time. Discuss the similarities and differences between the two circuits. 3) Finally, compare and contrast the two types of power transmission on a larger scale, discussing how they are similar and different.In summary, power loss is reduced in AC when transmitted due to the use of transformers. High voltage DC is used for some long transmission lines, but it's not as common as AC.
Daniel2244
125
why is there a loss of energy in DC circuits and power loss is reduced in AC when transmitted
Loss of energy in a DC circuit is due to the resistance of the wire cauing the wire to heat up therefore energy is being lost by heat. Energy loss can be prevented in AC circuits when transmitted by using transformers to "boost" the voltage. The voltage can also be boosted in DC however it is more difficult.
That's pretty close to correct. The problem statement wasn't very explicit, but it sounds like you are talking about AC Mains power transmission over long-distance transmission lines. Can you say a bit more about why using high voltage for that energy transmission minimizes the energy losses?
https://www.extremetech.com/wp-content/uploads/2012/12/powerlines-ac-power-transmission-348x196.jpg
Likes Daniel2244
Same happens with AC.
You should explain why boosting the voltage reduces the power lost.
Likes Daniel2244
Is it becasue by using a higher voltage there is a lower current lower current therefore less impedence?
Close! Using the higher voltage for transmission means less current flows through the resistance of the wires, so there is less voltage drop in the wires and therefore less energy loss in the wire. :smile:
Likes Daniel2244
As you said earlier
would this also apply to circuits because I have to "Use diagrams and clear desciptions to show the differnces and similarities between DC and AC in simple electrical circuits. The Work should include loss of energy in DC circuits and power loss reduction of AC when transmitted". This baffels me as I can't think of a reason why there would be a loss of energy in DC circuits becasue the current doesn't have to travel long distances therefore the energy loss would be equal between AC and DC as AC wouldn't need stepping up. (Unless I'm overthinking) and the power lines are a circuit anyways thanks for the help :)
What Berkeman said.
Power loss = Current * Voltage drop
Voltage drop = Current * Resistance
so
Power loss = Current2 * Resistance
So reducing the current is very important. For the same power transmitted, if you double the voltage the current halves and the power loss goes down by factor of four.
Likes berkeman and Daniel2244
A power line is a "circuit", just a very big one.
High Voltage DC _is_ used for some long transmission lines although it's not as common as AC.
I think they are asking you to do several things to show your overall understanding. I would answer as follows...
1) Draw two versions of a simple circuit comprising a voltage source and resistor load or light bulb. One with a DC voltage source and one with an AC voltage source. Add graphs showing the voltage and current vs time to both drawings. Describe the circuits and graphs.
2) Draw another similar circuit to represent a voltage source/power station, long wires with resistance and a load/town. Explain how power loss in the wire is calculated.
3) Explain how increasing the voltage reduces the power loss for a given power transmitted. Perhaps with the aid of another drawing with transformers both ends.
Likes Daniel2244
Some DC circuits draw a lot of current. So much that even short wires have significant losses. Consider the starter motor in a car or truck. They can draw 100's of Amps. To reduce losses in the cables they make them fat. This is possible because the cables are reasonably short. It would be expensive to make power lines very much fatter because they are a lot longer. Truck starter motors draw more current than car starters so they also use 24V batteries in trucks rather than 12V batteries to keep things under control.
Likes Daniel2244
Thanks for the help much appreciated.
Likes berkeman
Related to Loss of energy and energy loss prevention in circuits
1. How does energy loss occur in circuits?
Energy loss in circuits occurs when energy is converted into forms that are not useful for the intended purpose. This can happen due to resistance in the wires, components such as resistors or capacitors, or other factors such as heat or electromagnetic interference.
2. What are the main causes of energy loss in circuits?
The main causes of energy loss in circuits include resistance, which leads to heat dissipation, and inefficiencies in components such as transformers or transistors. Other factors such as poor connections or faulty wiring can also contribute to energy loss.
3. How can energy loss in circuits be prevented?
One way to prevent energy loss in circuits is by using high-quality, low-resistance materials for wiring and components. Additionally, proper design and placement of components, as well as regular maintenance and inspection, can help minimize energy loss.
4. Is it possible to completely eliminate energy loss in circuits?
No, it is not possible to completely eliminate energy loss in circuits. Some amount of energy will always be lost due to factors such as resistance and heat dissipation. However, steps can be taken to minimize energy loss and improve overall efficiency.
5. How does energy loss affect the performance of circuits?
Energy loss can have a significant impact on the performance of circuits. It can lead to reduced efficiency, increased heat generation, and decreased lifespan of components. In extreme cases, it can even cause circuits to malfunction or fail completely.
