Losses in AC and DC power tranfer
In summary: The lack of AC-DC conversion at each end means that the DC signal can be much higher than the AC signal.
wmac
Hello,
I have forgotten most of the electricity physics we studied and I have problem describing/understanding a concept.
Does AC current produce less loss than a DC current? I found this statement in a website: "AC electricity loses less power over power lines than DC" (http://www.blueraja.com/blog/176/wh...c-instead-of-direct-current-dc-in-power-lines).
1- Is above statement correct? Could you describe it with electricity formulas?
2- In network engineering we prefer a line encoding (method of converting 0 and 1s into electrical signals) that produces a signal with a surface under the curve being almost zero (integral of the signal level being zero). Why is that? Does it result in less losses on the line?
Thanks
No. The reason we do that, is to ensure that there is no DC component in the signal. This is important if we want the signal to pass through a transformer on the way.
The amount of losses is mostly poroprtional to I^2. For the same power a higher voltage nees less current and thus less resistive losses. That is true AC or DC.
But the lack of capacitance problems with DC, allows the use of higher voltages. But it comes at the substantial cost of AC-DC conversion at each end and each tap point. At high voltages, corona losses also become significant.
DC is also useful to connect AC nets that are not synchronized with each other.
Related to Losses in AC and DC power tranfer
1. What is the difference between AC and DC power transfer losses?
The main difference between AC and DC power transfer losses is the way in which electricity is transmitted. In AC (alternating current) power transfer, electricity flows back and forth in a circuit, while in DC (direct current) power transfer, electricity flows in one direction. This difference leads to different types of losses in each system.
2. What are the main causes of losses in AC and DC power transfer?
The main causes of losses in both AC and DC power transfer are resistance and inductance. Resistance is the natural opposition to the flow of electricity, and it leads to the conversion of electrical energy into heat. Inductance is the property of a circuit that causes a voltage to be generated when the current changes, leading to energy losses in the form of magnetic fields.
3. How are AC and DC power transfer losses calculated?
AC and DC power transfer losses are calculated using Ohm's Law, which states that the voltage drop across a circuit is equal to the current through the circuit multiplied by the resistance. For AC power transfer, additional calculations are required to take into account the effects of inductance and capacitance.
4. What are the effects of losses in AC and DC power transfer?
The main effect of losses in AC and DC power transfer is a decrease in the overall efficiency of the system. This means that less of the electrical energy being transferred is actually being used for its intended purpose, resulting in higher energy costs and potential equipment damage due to overheating.
5. How can losses in AC and DC power transfer be reduced?
There are several ways to reduce losses in AC and DC power transfer, including using higher voltage and lower current, using thicker and more efficient conductors, and minimizing the length of the transmission lines. Power factor correction techniques can also be used to reduce losses in AC power transfer due to inductance and capacitance effects.
  • Electrical Engineering
