Low capacity, battery driven, explosion proof blower
In summary: Class 1 Div 1 seems awfully high. Are there any other classifications for this?In summary, I need to evacuate a small room of a flammable, explosive gas using a portable Class 1 Div 1 certified blower. The environment is Class 1 Div 1 and the rooms have valved piping that enable me to attach a device to the exterior. The main difficulty with this project is that the device has to be portable. Anything electrically driven from an external power source is out of the question because plugging it in could create a spark. I have examined some pneumatically driven pumps that may work, but they
spenser.good
Hello I am in a bit of an engineering bind. I need to evacuate a small room of a flammable, explosive gas that is at a nominal pressure of 3 mbar by pushing it from room to another room (both at equal pressure). The environment is Class 1 Div 1. The rooms have valved piping that enable me to attach a device to the exterior.
The main difficulty with this project is that the device has to be portable. So anything electrically driven from an external power source is out of the question because plugging it in could create a spark (also any blowers I have seen are far too large of a capacity). I have examined some pneumatically driven pumps that may work, but they are not designed for gases and most of them, even plastic ones, have some steel parts that could in the worst case scenario spark. Also these pumps are designed for liquid use so a gas may not work.
So now I am stuck. I have considered hand pumps, but again most of these have components that could spark and are designed for liquids. What would be ideal would be a small, battery ran, explosion proof Class 1 Div 1 certified blower. If anybody has any suggestions I would greatly appreciate it.
Welcome to the PF.
I did a google search on 12v explosion proof fan, and got some promising hits. Maybe try that search to see if any of the links get you what you want.
I also did a quick search using "ATEX blower" as keywords and came up with a portable venturi blower that works on compressed air or saturated steam.
This supplier has many Class 1 Division 1 blowers rated for applications like yours:
http://www.aqualitywater.com/hazardous-location-suspension-blowers.html
Contact them for your situation.
More choices:
http://www.magnalight.com/p-1920-Explosion-Proof-Fan--Blower---Electric--Portable--Hazardous-Location-Ventilation.aspx
Thank you all for your replies. However I am beginning to think the only solution to this problem is a small manually operated pump simply because the size of the room to be purged is so small (less than 90 cubic foot). However it would have to be made entirely out of a non sparking material, so aluminum or plastic. Is anybody aware of such a product, or of a resource who would be willing to design one?
Budget, I am unsure. Obviously this PVC pump would be preferable to a custom made pump of a groundable, non sparking material. The OSHA report frightens me, especially when there is concern regarding friction. They give advice on grounding, but whether or not I could do this properly without training is a concern. I think perhaps it is time to reevaluate the validity of this project, unless I can get a pump made of a non sparking material for a reasonable price.
Can you describe your application more. Lot of things seem weird:
(a) A 90 cuft room. That's hardly 5 feet sided cube. Can you even call it a "room"
(b) 3 mbar is that the gauge pressure? When you say you want to evacuate it what's the target end point pressure? That's a crucial detail.
It is a service box on top of a digester, it is very small. 3 mbar is the gage pressure, the original request was to bring the room down to atmosphere, and then open a valve to allow air entry and place a CH4 monitor inside the room to measure methane content and continue to pump out the gas (the entire pumping operation will direct the gas back into the headspace of the digester) in the room until it is safe. The device would have to be portable. This was an idea given to myself by a superior, and I am trying to determine how to do it, but it is very frustrating because nothing seems to be completely safe due to a host of reasons. A summary of the options I have examined and their reasons for being unsafe or impractical:
- a small blower : every blower I have seen would be much too large to perform this action, and would cause too much of a vacuum inside the service box, on top of this all blowers need an external power source and if it is portable it would have to be plugged in, creating a potential spark source
- a pneumatic diaphragm pump: none of these are designed to move gases, and although they may work, using a device not designed to move gases on an explosive gas seems foolish. Also, although it is possible to get a pump in conductive nylon so it is groundable, there are still steel clips and structural components in the pump that could spark if the device were to malfunction, which also concerns me
-a hand operated PVC pump: although the material is non sparking, static electricity buildup is concerning to me
-a venturi blower: would pull in too much air into the digester
I think this may be a project not worth the risk. If anybody else can think of any other options, let me know. Short of a very expensive custom made hand pump constructed out of a groundable, spark proof material such as aluminum or copper, I cannot think of a perfectly safe or practical option.
Umm -- Pretty sure fire companies use this type of device... OH -- THanks Google... Intrinsicly Safe.
Ref: http://www.firerescue1.com/fire-pro...1356972-Ventilation-fans-6-types-to-consider/
Ref: http://store.gomed-tech.com/ramfan-intrinsically-safe-16-electric-smoke-ejector-p1796.aspx
I can not think of any case where seeking professional input or support on anything explosive is not the proper course of action. I like DIY myself - but this would not be a case for it.
Also -- look into laboratory hoods and ventilators - they will probably use the same Intrinsically Safe language for working with solvents.
I agree completely. I think a blower as you have recommended would be the best course of action if the process just involved purging the room. It is pulling a vacuum to quickly with one of these blowers during depressurizing that concerns me. Right now I am putting this hold until I have a chance for further consultation. Thanks everyone for their help!
Somehow your approach sounds wrong. 3 mbar is a very tiny excess over atmospheric anyways.
Can you provide details as to what exactly is the composition? Isn't just plain venting to atm. an option? Even if you want to vent to the digestor headspace why not have a one way, non return breather valve on the room? That way no vacuum will result. Air drawn in will continually replace the gas. If you don't like air push in N2.
What's the pressure / vacuum rating of the box. Why not inert & purge in cycles? No pump will be needed.
Another way to avoid a blower: Create a vacuum in a secondary chamber & use that to draw in the vapors. Pump is never on during vapor exposure.
I agree, approximately 1 cubic foot of gas needs to be displaced to bring down to atmosphere. This project was not conceived by myself, and these are flaws I have already thought of. I need to discuss within my group. I have a feeling not too much consideration was made when conceiving this idea. Thanks for reply.
Related to Low capacity, battery driven, explosion proof blower
1. What is a low capacity, battery driven, explosion proof blower?
A low capacity, battery driven, explosion proof blower is a piece of equipment used for ventilation and air circulation in areas where there is a risk of explosion. It is designed to be portable and powered by batteries, making it suitable for use in remote or hazardous environments.
2. How does a low capacity, battery driven, explosion proof blower work?
A low capacity, battery driven, explosion proof blower works by drawing in air through an intake and then forcing it out through a discharge. The air is typically directed towards a specific area or space to provide ventilation and prevent the build-up of explosive gases.
3. What are the benefits of using a low capacity, battery driven, explosion proof blower?
Some of the benefits of using a low capacity, battery driven, explosion proof blower include its portability, versatility, and safety features. As it is powered by batteries, it can be easily transported and used in various locations. It is also designed to be explosion proof, preventing any potential accidents or hazards in hazardous environments.
4. What are some common applications of a low capacity, battery driven, explosion proof blower?
A low capacity, battery driven, explosion proof blower is commonly used in industries such as mining, oil and gas, and chemical processing. It is also used in confined spaces, such as tanks or vessels, where there is a risk of explosion due to the presence of flammable gases.
5. How do I choose the right low capacity, battery driven, explosion proof blower for my needs?
When choosing a low capacity, battery driven, explosion proof blower, it is important to consider the specific requirements of your environment and the type of materials or gases present. Factors to consider include the size and capacity of the blower, its power source and battery life, and any additional safety features. It is recommended to consult with a professional or do thorough research before making a purchase.
  • Mechanical Engineering
  • New Member Introductions
