Low-cost low threshold optical beam limiter?
In summary: How many lasers are in use at a time?5) What are the dimensions of the beam?6) What is the power of the laser?7) What are the dimensions of the beam?8) What is the power of the laser?9) What are the dimensions of the beam?10) Is the laser Class II, Class III, or Class IV?11) What is the power of the laser?12) What are the dimensions of the beam?13) What are the dimensions of the beam?14) What are the dimensions of the
flux!
34
Do you guys know a low-cost low-threshold optical beam limiter, with cost somewhere ~$100.
Or if you know certain method to fabricate such. I would be greatful if you could include links and/or references.
I am still noob in photonics so I am only familiar with a beam limiter that blocks the entire incoming lase beam when its intensity is at a certain threshold of the beam limiter. In other case the beam limiter will always permit laser beam that has less than the threshold intensity.
Science news on Phys.org
What wavelength is your laser? Perhaps you could use a configuration with a Photchromic Lens: https://en.wikipedia.org/wiki/Photochromic_lens
For higher beam intensities, the lens will darken more, letting less of the beam through... :smile:
Likes flux!
It's not clear what you are looking for- first, what is/are the wavelengths? What are the ranges of input power and output power? What timescale does the intensity adjustment require- seconds, nanoseconds...? What is the cross-section of the optical beam? Etc. etc. etc.
I will certainly look into photochromatic lenses :)
By the way, we got this laser:
Wavelength: Red, 620–750 nm
Power: 1 mW
Cross-section: 1 mm Diameter
Timescale intensity adjustment: No idea, newbie photonics researcher here.
Optical Beam Limiter I am looking:
Price: Low cost (I got $2000 research grant, that is already everything)
Activation time: 1 ns or faster (I mean, instant activation when the threshold is reached)
You could also do a manual rotary optical attenuator disc if that met your experimental requirements... :smile:
Power: 1 mW
If I understand you correctly, you are working with a Class II CW laser (ANSI Z-136.1 standard), which doesn't require anything fancy, a simple mechanical shutter or beam blocker will suffice- your 'blink response' provides sufficient protection to accidental exposure. The laser output power is constant, yes?
Or am I misunderstanding the problem you are trying to solve?
Yes, the power is constant, as much as possible I would like to avoid mechanical parts, right now I am looking into photochromatic lenses, but would welcome other types of lenses/material, could you suggest a link to simple blocker?
I get that you are itching to buy something, I'm trying to slow you down to first figure out exactly what you need. I guess I still don't understand what problem you are trying to solve (and I don't mean 'the problem is that I need to buy an optical limiter'). For example:
1) Is this 'limiter' device intended to make the laser eye-safe? Class II devices are best made eye-safe manually- turn the laser off or shutter the beam when needed, use goggles when the laser is on, things like that. Class III and Class IV lasers require automatic shut-offs- door interlocks, for example- in addition to other controls.
2) Is this device intended for some other purpose, for example, learning about laser safety and designing the appropriate controls?
3) How is the laser being used? For example, will this be a laser taken into a large lecture hall that makes use of goggles impractical? Is the laser in a laboratory setting with a few people near the beam? Is the laser fixed in position, or will it be moved from place to place?
4) Where is the beam going? Is it going into a free-space optical system where the possibility of accidental scattering/errant beam is moderate, or is the beam going into an enclosed device (spectrometer, etc)?
If you just want to buy a photochromic lens and move on, by all means go ahead- but realize that you may not have solved your problem.
If you want nanosecond activation time, I don't think photochromic lenses will work for you.
Yhea, thanks for pointing that out, I guess photochromic lenses will be listed out.
Its more like number 4, the beam will go into an enclosed device, no other peoples eyes will get hurt. I am planning to supper impose monochromatic red beams and the limiter will act like a fast switch when a threshold is reached.
Related to Low-cost low threshold optical beam limiter?
1. What is a low-cost low threshold optical beam limiter?
A low-cost low threshold optical beam limiter is a device used to control the intensity of a laser beam. It limits the power output of the laser beam to a safe level, preventing damage to sensitive equipment or the human eye.
2. How does a low-cost low threshold optical beam limiter work?
The limiter uses a combination of absorbing materials and/or nonlinear optical effects to attenuate the laser beam. It can either reflect or absorb excess energy, depending on the design, to prevent damage to the laser and surrounding objects.
3. What are the advantages of using a low-cost low threshold optical beam limiter?
One advantage is its affordability compared to other types of beam limiters. It also has a low threshold, meaning it can quickly respond to high-intensity laser beams, making it a reliable safety mechanism. Additionally, it is compact and easy to integrate into existing laser systems.
4. Are there any limitations to using a low-cost low threshold optical beam limiter?
One limitation is that it may not be suitable for high-power laser beams, as it may not be able to attenuate the intensity enough. It also requires regular maintenance and calibration to ensure its effectiveness. Additionally, it may have a limited wavelength range that it can effectively attenuate.
5. How can I choose the right low-cost low threshold optical beam limiter for my application?
To choose the right limiter, you should consider the power and wavelength of your laser beam, as well as the maximum attenuation needed. You should also factor in the size and compatibility with your current laser system. It is recommended to consult with a specialist or manufacturer for guidance.
  • Atomic and Condensed Matter
