Low temperature production with compressed air
In summary: The exhausted steam is at a pressure well below...the atmospheric pressure, and it must be compressed to a higher pressure in order to be released into the atmosphere.
pranj5
386
Suppose, there are two cylinders of compressed gas, say air. Both are at same temperature and pressure and the amount too is same.
Now, contents of both are released but in a different way. One has been released directly and the other has been released through compressed air turbine having a generator attached to it. Therefore, some amount of power/electricity has been generated by the second. I want to know which one will be able to produce more cold.
Common sense tells that it's the second because by this process that dynamic energy of the compressed air has been converted into power/electricity and it should has lesser energy than the first where the velocity of release has been converted into random motion of molecules i.e. heat.
Am I right or wrong?
Good question ! ...I have some thoughts ...
If a cylinder is inside a room and contents are emptied into this closed room , the cylinder will be cooler but the room would have heated up , no net temperature change.
If a turbine is connected and electricity (heat) is taken out of the room by wires then surely this room will be cooler than the first .
Well, that's the same as mine. Glad to know that I have been supported by at least one. But, I want more to be sure.
Actually, I have come up with an idea of increasing the efficiency of thermal power plants and it suddenly struck my mind if the temperature at the Condenser section is lowered, the efficiency and output can be increased. Now, if we use compressed air to rotate a turbine and then use that colder air to create lower temperature at the Condenser; I am sure that the increase in output will outrun the power needed to compress air or other gaseous fluid.
I'm not sure how lowering the temperature of the condenser would increase efficiency , unless it allowed use of a different working fluid with a lower boiling point ( practically impossible)...after all , we only need to condense steam to water at 100C and pump it back to the boiler , very easy.
Raising the the max temp.would increase efficiency.
That's very basic physics. You can increase the efficiency of thermal based system by either increasing temperature at the Boiler or by decreasing temperature at the Condenser. Pressure at the Condenser can be varied and therefore we can control the temperature at the Condenser and engineers often try to reduce the pressure as much as possible so that efficiency can be increased.
Turbines don't convert heat to work, they convert pressure to work. It seems to me the best an expansion cycle can do (regardless of whether it's a turbine or expansion valve) is follow an isentropic expansion curve. In that case from the same starting point they will both result in the same end state. In practice the turbine will have an efficiency associated with it that will result in a state slightly off of isentropic, but there isn't really a way to calculate the efficiency of a valve since it doesn't produce work. In any case, they will best-case result in the same end-state.
At this wiki page one steam turbine, it has been clearly said that the steam gains velocity by passing through a nozzle shaped path inside the turbine that is called the stator. That means not only the pressure, but also the heat of the steam itself has also been converted into work inside the turbine, to precise at the stator section.
If just pressure will be enough, then why steam is superheated in thermal power plants to get higher efficiency?
You're right ...I had assumed the final exhaust steam pressure was atmospheric ,... but from wikepedia .."The exhausted steam is at a pressure well below atmospheric,"...
This answer is easily answered with a Google search:
http://web.mit.edu/16.unified/www/FALL/thermodynamics/notes/node66.html
web.mit.edu said:
[In a superheated Rankine Cycle] The heat addition is continued past the point of vapor saturation, in other words the vapor is heated so that its temperature is higher than the saturation temperature associated with . This does several things. First, it increases the mean temperature at which heat is added, http://web.mit.edu/16.unified/www/FALL/thermodynamics/notes/img1161.png , thus increasing the efficiency of the cycle. Second is that the quality of the two-phase mixture during the expansion is higher with superheating, so that there is less moisture content in the mixture as it flows through the turbine. (The moisture content at http://web.mit.edu/16.unified/www/FALL/thermodynamics/notes/img257.png is less than that at http://web.mit.edu/16.unified/www/FALL/thermodynamics/notes/img1166.png .) This is an advantage in terms of decreasing the mechanical deterioration of the blading.
Thank you Mech_Engineer, the part that you have posted clearly supports my claim. Increasing temperature i.e. superheating steam means increasing efficiency and that will lead to higher output. In short, by increasing temperature we can increase output and that isn't possible until and unless a part of the extra heat will be converted into power.
It is well-know that superheating in a Rankine Cycle increases efficiency. There are also more complex "superheat with regeneration" Rankine cycles which re-heat the fluid a little in between stages of a multi-stage turbine. The goal is to follow the saturation curve and extract as much energy as possible out of the fluid.
http://web.mit.edu/16.unified/www/FALL/thermodynamics/notes/fig6RankineReheat_web.jpg
Keep in mind (as I said before) turbines convert pressure into mechanical work. A turbine does not convert heat directly to work, the advantage of superheating the steam is to increase its pressure (and to increase steam quality after expansion through the turbine). When you think practically about a turbine, it is a set of blades which must be pushed by the working fluid; this net force doesn't come from the fluid's temperature, it comes from pressure.
In Boilers of thermal power plants, the mode of heating is isobaric i.e. pressure remains constant during compression. Inside the turbine at the stator section, this additional heat will be converted into dynamic pressure and that will drive the blades of the rotors of the next stage. Overall, heat will certainly be converted into energy by a turbine but in the stator section, it has been converted into velocity i.e. dynamic pressure and then into energy by rotating the rotor.
I'm not aware of any process step which directly converts "additional heat into dynamic pressure." You might read through this section of my previous link to gain some more insight though:
web.mit.edu said:
Figure 8.17: Effect of maximum boiler pressure on Rankine cycle efficiency
http://web.mit.edu/16.unified/www/FALL/thermodynamics/notes/fig6RankineVaryMaxPressure_web.jpg
Another design parameter is the maximum cycle pressure. Figure 8.17 shows a comparison of two cycles with different maximum pressure but the same maximum temperature, which is set by material properties. The average temperature at which the heat is supplied for the cycle with a higher maximum pressure is increased over the original cycle, so that the efficiency increases.
Some excerpts from wikipedia:
An impulse turbine has fixed nozzles that orient the steam flow into high speed jets. These jets contain significant kinetic energy, which is converted into shaft rotation by the bucket-like shaped rotor blades, as the steam jet changes direction. A pressure drop occurs across only the stationary blades, with a net increase in steam velocity across the stage. As the steam flows through the nozzle its pressure falls from inlet pressure to the exit pressure (atmospheric pressure, or more usually, the condenser vacuum). Due to this high ratio of expansion of steam, the steam leaves the nozzle with a very high velocity. The steam leaving the moving blades has a large portion of the maximum velocity of the steam when leaving the nozzle. The loss of energy due to this higher exit velocity is commonly called the carry over velocity or leaving loss.
Source: https://en.wikipedia.org/wiki/Steam_turbine
By definition a nozzle uses a pressure differential to create velocity. In your provided reference:
The temperature of the fluid drops as a result of the pressure drop within the turbine as a system as work is generated.
I'm aware of that thread, I see no useful information in that thread w.r.t. the posted question in this thread.
A nozzle by itself will not convert temperature to velocity (a.k.a. kinetic energy). The purpose of a thermodynamic process like the Rankine Cycle as a whole is the conversion of heat (combustion source) to mechanical work.
FAQ: Low temperature production with compressed air
What is low temperature production with compressed air?
Low temperature production with compressed air is a method of cooling or refrigeration that uses compressed air as the primary source of energy. It involves compressing air to high pressures, which increases its temperature, and then expanding the air through a refrigeration process to produce cold temperatures. This process is commonly used in industrial settings for applications such as food processing, chemical production, and refrigeration systems.
How does low temperature production with compressed air work?
The process of low temperature production with compressed air involves compressing air using a compressor and then passing it through a heat exchanger, which removes the heat from the compressed air. The cooled air is then expanded through a turbine or expansion valve, which causes the temperature to drop significantly. This cold air is then used to cool or freeze products, or to maintain a low temperature in a production process.
What are the benefits of using low temperature production with compressed air?
There are several benefits to using low temperature production with compressed air. Firstly, it is a more energy-efficient method compared to traditional refrigeration systems. Additionally, it is a more environmentally friendly option as it does not use harmful refrigerants. It also allows for precise temperature control, making it suitable for a wide range of applications. Furthermore, compressed air is a readily available source of energy, making it a convenient and cost-effective option.
Are there any limitations to low temperature production with compressed air?
Although low temperature production with compressed air has many advantages, it also has some limitations. The initial cost of setting up a compressed air system can be high, and regular maintenance is required to ensure efficient operation. Additionally, the expansion process can cause a significant drop in air pressure, which may limit the distance that the cold air can be transported. It is also not suitable for applications that require extremely low temperatures.
What are some common applications of low temperature production with compressed air?
Low temperature production with compressed air has a wide range of applications, including food processing, chemical production, and refrigeration systems. It is commonly used in the food and beverage industry to cool or freeze products such as meat, fish, and vegetables. In the chemical industry, it is used for cooling and condensing gases and liquids, as well as for maintaining low temperatures in various production processes. It is also used in refrigeration systems for commercial and industrial buildings, as well as in the transportation of temperature-sensitive goods.
