Low volume heard in phone calls, How to raise the volume?
  • Thread starter Thread starter WWGD
    Android Volume
The user is experiencing low volume during conversations on their LG K8 Android 2018. Suggestions for troubleshooting include checking signal strength, using earphones or headphones, and testing the speakerphone function. The issue may be related to the microphone rather than settings, as there are no Android settings to adjust microphone volume. A recommended method to diagnose the problem involves using video conferencing apps like Google Meet, Zoom, or WhatsApp to determine if the microphone issue persists in those applications. Testing in different environments and with various devices can help isolate the problem.
WWGD
TL;DR
Cannot hear others clearly during phone calls on LG Android . Tried changing settings unsuccessfully.
Hi,
I have an LG K8 Android 2018. I am having trouble with the volume in conversations. I tried changing different settings without success. Any suggestions on how to raise the volume level during conversations? Is it a physical issue of wear and tear of the microphone, an issue with settings, etc?
Thanks.
Computer science news on Phys.org
Sometimes it is a problem of signal strength. There should be an indicator on the phone. Moving around could help.
Do you face this problem if you use earphones/headphones (Bluetooth/wired)? If you turn on speaker, is the volume still low? Has this problem started since some time, or was it there when you bought the phone?
Thank you. I tried a while back ; will try again. Sorry if I'm being lazy; thought maybe I was missing something simple. Last I tried using the speaker, I could hear better on my end but was told by those on the other end that they could not hear me.
Okay, I thought it was an issue with both speaker and microphone. If it is only the microphone, then there is no Android setting to change the volume of the mic, as far as I know. Assuming you have a Google account, try this: download the Google Meet app on your phone, and on a separate phone of someone else. Start a meeting, and add the second person. You two should sit in two rooms far away, preferably on two ends of your house, or in different floors. If on the same floor, close the doors. Now try speaking. Can the other person hear you? Can you hear them?
If they can't hear you, is the problem solved if you use headphones/earphones?
If you have Zoom or WhatsApp, even that will work. Don't use the normal voice call system.
Let us know the results.
Thread 'ChatGPT Examples, Good and Bad'
I've been experimenting with ChatGPT. Some results are good, some very very bad. I think examples can help expose the properties of this AI. Maybe you can post some of your favorite examples and tell us what they reveal about the properties of this AI. (I had problems with copy/paste of text and formatting, so I'm posting my examples as screen shots. That is a promising start. :smile: But then I provided values V=1, R1=1, R2=2, R3=3 and asked for the value of I. At first, it said...
27K
