Loxodrome - found a mistake on Wolfram MathWorld site?
  • Thread starter kkz23691
  • Tags
    Mistake
Is there something wrong with this calculation?In summary, the claim on the Wolfram MathWorld site about the curve given in oblate spheroidal coordinates being a loxodrome is not true. This is because the angle with respect to all meridians is not constant, as shown by the calculation that the cosine of this angle is not constant when the parameters are varied.
kkz23691
47
Hello,
Could it be?... We find this claim on Wolfram MathWorld site http://mathworld.wolfram.com/SphericalSpiral.html
The claim is that this curve (given in oblate spheroidal coordinates in the limit where the spheroid is a sphere, measuring the inclination angle ##c## with respect to the xy-plane and making the unusual choice of putting a "minus" sign in z)
##{\mathbf r}_x=\cos t \cos c##
##{\mathbf r}_y=\sin t \cos c##
##{\mathbf r}_z=-\sin c##
where
##c=\tan^{-1}(at)##
is a loxodrome - a curve that lies on the sphere and forms the same angle with all meridians as it winds around the sphere.
Then the angle with respect to all meridians must be the same. This means (take ##p## as an independent parameter)
##\cos\alpha=\frac{\frac{d{\mathbf r}}{dc}\cdot \frac{d{\mathbf r}}{dp}}{|\frac{d{\mathbf r}}{dc}| |\frac{d{\mathbf r}}{dp}|}=\mbox{const}##
It seems that this is not true!
Proof:
Since ##c## is the inclination angle, ##\frac{d{\mathbf r}}{dc}## is a vector tangential to the meridian. Its components are:
##\frac{d{\mathbf r}_x}{dc}=-\cos t \sin c##
##\frac{d{\mathbf r}_y}{dc}=-\sin t \sin c##
##\frac{d{\mathbf r}_z}{dc}=-\cos c##
Now, the sphere is a surface parameterized with 2 parameters ##(c,t)##; let the loxodrome be parameterized with one parameter ##p## such that ##(c,t)=(c(p), t(p))##. Then
##{\mathbf r}_x(p)=\cos t(p) \cos c(p)##
##{\mathbf r}_y(p)=\sin t(p) \cos c(p)##
##{\mathbf r}_z(p)=-\sin c(p)##
Then the vector tangent to the curve is ##\frac{d{\mathbf r}}{dp}## and its components are
##\frac{d{\mathbf r}_x}{dp}=-(\sin t \cos c) t^{\prime} - (\cos t \sin c) c^{\prime}##
##\frac{d{\mathbf r}_y}{dp}= (\cos t \cos c) t^{\prime} - (\sin t \sin c) c^{\prime}##
##\frac{d{\mathbf r}_z}{dp}=-(\cos c) c^{\prime}##
After taking into account that for any vector ##{\mathbf x}## it is true that ##|{\mathbf x}| = \sqrt{{\mathbf x}\cdot{\mathbf x}}##, the norm of this vector is ##|\frac{d{\mathbf r}}{dp}| = \sqrt{c^{\prime 2} + t^{\prime 2} \cos^2 c}## and ##|\frac{d{\mathbf r}}{dc}| =1##.
The dot product ##\frac{d{\mathbf r}}{dc}\cdot \frac{d{\mathbf r}}{dp}## turns out to be equal to ##c^{\prime}##. Then
##\cos\alpha=\frac{c^{\prime}}{ \sqrt{c^{\prime 2} + t^{\prime 2} \cos^2 c}}##
Now Mathworld claims that ##t## is an independent parameter and ##c(t)=\tan^{-1}(at)##. Then ##t^{\prime}=\frac{dt}{dt}=1## and ##c^{\prime}=\frac{dc}{dt}=\frac{1}{1+a^2t^2}##.
Plugging in into the expression for ##\cos\alpha## yields
##\cos\alpha=\frac{1}{\sqrt{1+2a^2t^2}}\neq \mbox{const}##
Therefore, the curve given above is not a loxodrome?
Thanks for the post! Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post?
I pdf-ed the proof and emailed it to mathworld. Hopefully, they will check and let me know.
Your calculations have errors. For instance the formula for c' is wrong.
Notice that cos(c) = 1/(1 + (at)^2)
Likes kkz23691
Hello Lavinia,
thank you for reviewing this long post!
Here is my reasoning:
##c^{\prime} = \frac{dc}{dt}= \frac{d}{dt}\tan^{-1}(at)= \frac{d}{dt}\arctan(at)=\frac{1}
{1+a^2t^2}##
As far as cos(c) is concerned:
Take a right-angled triangle with sides 1, x and hypothenuse equal to ##\sqrt{1+x^2}##.
Then the angle over-against x is ##\arctan(x)##. The cosine of this same angle is equal to ##\frac{1}{\sqrt{1+x^2}}##
Thus,
##\cos(\arctan(x)) = \frac{1}{\sqrt{1+x^2}}##
This means
##\cos(c) = \cos(\arctan(at)) = \frac{1}{\sqrt{1+a^2t^2}}##.
kkz23691 said:
Hello Lavinia,
{1+a^2t^2}##
Thus,
This means
The derivative of the arctangent(x) is 1/(1+x^2) but you want arctangent(ax). You forgot to use the Chain Rule.
I get cos(c) for the dot product of the derivative of the curve with the unit tangent to the meridian. What do you get?
Likes kkz23691
##a## is a constant. Only ##t## is a variable. Sorry, I should have said this earlier. In the end, a 3-d curve is to depend on only one variable say ##t##: ##{\mathbf r}={\mathbf r}(t)##
This would mean that the derivative ##\frac{dc}{dt}## will treat ##a## as a constant.
I see you have found this error in my derivation:
I wrote:
##\frac{d(\arctan(at))}{dt} = \frac{1}{1+a^2t^2}##
while the correct derivative is:
##\frac{d(\arctan(at))}{dt} = \frac{a}{{1+a^2t^2}}##
I get ##c^{\prime}##. Here is my reasoning:
##\frac{d{\mathbf r}_z}{dc} =−\cos c##
The vector tangent to the curve is ##\frac{d{\mathbf r}}{dp}## and its components are
Then
##\frac{d{\mathbf r}}{dc}\cdot \frac{d{\mathbf r}}{dp} = c^{\prime}##.
Then
You are correct. I was taking the inner product with a latitude nor a longitude.
Likes kkz23691
Thank you for your time. I checked and even after correcting the derivative of the ##\arctan(ax)## the cosine of the angle is still not a constant. It looks like this curve is not a loxodrome...
I rechecked your calculations a few times and think they are now correct.
I suspect that the Wolfram article has a typo and c should be the inverse tangent of a^t not a.t.
If you solve for the curve in the unit disk that makes a constant angle with the radial lines emanating from the origin, you get a logarithmic spiral. Project this spiral into the unit sphere via stereographic projection. This will be a curve that makes a constant angle with the meridians,this because the radial lines project to the meridians and stereographic projection is a conformal map.
I got the curve,
( sech(Kt)cos(t), sech(Kt) sin(t), -tanh(Kt)).
where K is a constant that depends on the cosine of the angle of intersection of the radial lines with the logarithmic spiral.
This curve in spherical coordinates is
( cos(f(Kt))cos(t), cos(f(Kt))sin(t),-sin(f(Kt)))
where the function,f, is the inverse sin of tanh(Kt).
I found an identity says that f can be expressed as the arcsine of an exponential. Take a look at the Wikipedia article on the Gudermannian function for this identity.
Likes kkz23691
FAQ: Loxodrome - found a mistake on Wolfram MathWorld site?
1. What is a loxodrome?
A loxodrome, also known as a rhumb line, is a line on a sphere that intersects all meridians at the same angle. It is often used in navigation to determine a constant heading between two points.
2. How is a loxodrome calculated?
A loxodrome is calculated using the spherical law of cosines, which takes into account the latitude and longitude of the starting and ending points. The formula is d = R * Δλ * cos(φ), where d is the distance between the two points, R is the radius of the sphere, Δλ is the difference in longitude, and φ is the latitude.
3. What mistake was found on the Wolfram MathWorld site regarding loxodromes?
The mistake found on the Wolfram MathWorld site was in the formula for calculating distance on a loxodrome. The site used the formula d = R * Δλ * sin(φ), which is incorrect. The correct formula is d = R * Δλ * cos(φ).
4. How does the mistake on the Wolfram MathWorld site affect the calculation of loxodromes?
The mistake on the Wolfram MathWorld site affects the calculation of loxodromes by providing an incorrect distance between two points. This can lead to errors in navigation or other applications that rely on accurate loxodrome calculations.
5. Has the mistake on the Wolfram MathWorld site been corrected?
Yes, the mistake on the Wolfram MathWorld site has been corrected. The site now uses the correct formula for calculating loxodromes, d = R * Δλ * cos(φ). However, it is always important to double check formulas and calculations to ensure accuracy.
