LP graphical method true/false Q
In summary, the LP graphical method is a problem-solving approach used to solve linear programming problems with true/false decision variables. It involves drawing a graph with two axes, one representing the objective function and the other representing the constraints. The feasible region, where all constraints are satisfied, is then identified and the optimal solution is determined. True/false decision variables are used to represent binary decisions and are subject to constraints and an objective function. The advantages of using this method include its visual representation, ability to handle complex problems, and simplicity. However, it is limited to linear programming problems with a small number of decision variables. The solution obtained from this method is optimal when the feasible region is a convex polygon and the objective function is a straight line. Otherwise,
csc2iffy
76
Label each of the following statements as True or False, and then justify your answer based on the graphical method. In each case, give an example of an objective function that illustrates your answer.
(a) If (3,3) produces a larger value of the objective function than (0,2) and (6,3), then (3,3) must be an optimal solution.
(b) If (3, 3) is an optimal solution and multiple optimal solutions exist, then either (0,2) or (6,3) must also be an optimal solution.
(c) The point (0,0) cannot be an optimal solution.
I posted the attachment of the picture
I said...
(a) False, (3,3) cannot be an optimal solution because ? I just think it's because (6,3) would always be greater, I can't think of an example where it wouldn't be
(b) False, either (3,3) and (0,2) are optimal, or (3,3) and (6,3) are optimal.
(c) True
I need a little help justifying my answers and finding an example of an objective function illustrating my answers.
(a) False. The graphical method involves plotting the constraints and finding the feasible region, which is the area where all constraints are satisfied. The optimal solution is the point within the feasible region that maximizes or minimizes the objective function. Just because (3,3) produces a larger value of the objective function than (0,2) and (6,3) does not necessarily mean it is the optimal solution. It could be that there is another point within the feasible region that produces an even larger value of the objective function. For example, if the objective function is to maximize profit and the constraints are x + y ≤ 4 and 2x + y ≤ 6, the feasible region is the shaded area bounded by the two lines and the coordinate axes. The point (3,3) is within the feasible region and produces a profit of 6, but the point (2,4) also satisfies the constraints and produces a profit of 8, which is larger. Therefore, (3,3) is not necessarily the optimal solution.
(b) False. If (3,3) is an optimal solution, it means that it is the best possible solution within the feasible region. If there are multiple optimal solutions, it means that they all produce the same optimal value of the objective function. Therefore, if (0,2) or (6,3) were also optimal solutions, they would produce the same optimal value as (3,3). This would mean that the point (3,3) is not the best possible solution, which contradicts the definition of an optimal solution.
(c) True. The point (0,0) is the origin and is outside of the feasible region. Since the optimal solution must be within the feasible region, (0,0) cannot be an optimal solution. An example of an objective function that illustrates this is to maximize revenue with the constraints x ≥ 0 and y ≥ 0. The feasible region is the first quadrant and the origin is outside of it. Therefore, (0,0) cannot be an optimal solution.
Related to LP graphical method true/false Q
1. What is the LP graphical method for true/false questions?
The LP graphical method is a problem-solving approach used to solve linear programming (LP) problems with true/false decision variables. It involves drawing a graph with two axes, one representing the objective function and the other representing the constraints. The feasible region, where all constraints are satisfied, is then identified and the optimal solution is determined.
2. How do true/false decision variables work in LP graphical method?
In LP graphical method, true/false decision variables are used to represent binary decisions, where a value of 1 represents a true decision and a value of 0 represents a false decision. These variables are subject to certain constraints and an objective function, and the goal is to find the combination of true/false values that maximize or minimize the objective function.
3. What are the advantages of using LP graphical method for true/false questions?
One advantage of using LP graphical method for true/false questions is that it provides a visual representation of the problem, making it easier to understand and solve. It also allows for multiple constraints and decision variables to be included in the problem, making it suitable for complex problems. Additionally, it is a relatively simple and straightforward method compared to other LP techniques.
4. Are there any limitations to using LP graphical method for true/false questions?
One limitation of LP graphical method for true/false questions is that it can only be used for linear programming problems, where the objective function and constraints are linear. It is also only applicable for problems with a small number of decision variables, as the graph becomes more complex and difficult to interpret with a larger number of variables.
5. How do you know if the solution obtained from LP graphical method for true/false questions is optimal?
The solution obtained from LP graphical method for true/false questions is optimal when the feasible region is a convex polygon and the objective function is a straight line. This means that the optimal solution is at one of the vertices of the feasible region. If the objective function is not a straight line, it is necessary to check all the vertices of the feasible region to determine the optimal solution.
