I Lux-meter, candelas or lux, measuring nits in practice
To measure a display's luminance in nits using a lux-meter, one must understand the relationship between illuminance (lux), luminous intensity (candelas), and luminance (nits). The lux-meter measures illuminance, which can be converted to luminance by considering the solid angle and distance from the display. A practical method involves placing a circular aperture in front of the screen, positioning the sensor at a calculated distance, and ensuring that only light from the screen reaches the sensor. The formula for luminance in nits can be derived from the lux reading by adjusting for the area and angle of the aperture. Accurate measurements require careful setup to avoid interference from other light sources.
flying_bear
TL;DR Summary
My lux-meter can be used in two modes, candela and lux. How do I use it to accurately measure a display's luminance in nits?
My lux-meter can be used in two modes, candela and lux. How do I use it to accurately measure a display's luminance in nits?​
The screen isn't Lambertian, I have to assume this as an unknown. I'm interested in the luminance as seen by the eye looking at the screen perpendicular to it.
Now, first some definitions, so we talk about the same thing and we avoid lectures:
LUMINOUS FLUX: Measured in lumens.
ILLUMINANCE: Lux is measured in luminous flux/area, thus lumen/m^2.
LUMINOUS INTENSITY: Candela. Measured in luminous flux per solid angle (think of it as a cone), lumens/sr.
LUMINANCE: Measured in luminous flux per solid angle per area, candelas/m^2. Nit: Another term for luminance, 1 nit=1 candela/m^2.
My lux-meter is only a sensor that measures luminous flux per solid angle (candelas), and can also show lux, which is simply candelas/distance^2. This is why the distance has to be entered into the lux-meter. It's nothing magical, just a light sensor with certain properties.
Placing the sensor onto the screens in question, I get candela values that are pretty close to the display's rated nits. But luminance does not equal luminous intensity.
I find online conversion calculators that strangely just equates illuminance with luminance. They're not the same! It's like saying that kilos potatoes planted per square meter equals kilos potatoes shot from a tater in a certain solid angle (cone) per square meter. It would vary with the solid angle used! It's potatoes per angle^2 per meter^2. One cannot simply just ignore the angle^2! Or can one?
My question is simply: HOW DO I USE MY SIMPLE LUX-METER TO MEASURE MY DISPLAY'S NITS RATING? I have scoured YouTube and the web for this, have strangely found no clear and practical instructions on how to proceed.
The closest I have found is this:
... all that is involved to find stimulus luminance is measuring the illuminance produced by the stimulus at the location of the eye and dividing by the solid visual angle of the stimulus. However, two other matters need to be considered.
(1) Lacking a lens, an illuminance meter is not directionally selective of the light to which it responds. Therefore, one must ensure that only light from the stimulus reaches the detector.
(2) Calculating the solid angle of a stimulus is easy enough if it is round. If it is not round, use a slightly smaller circular aperture and place it directly in front of the stimulus. Then calculate this aperture’s solid angle. A little work and some math can save thousands of dollars.
So, would the procedure be to
  1. Cover the screen with a circular aperture, radius r
  2. Place the sensor at least 5*r away (so we assume the convex surface as flat), distance d
  3. Calculate the solid angle sr as d/r^2.
  4. Make sure there are no other light sources, point the lux-meter towards the center of the aperture at distance d
  5. Read the lux value lx (having entered the distance into the lux-meter, or just using candelas?)
  6. Luminance in nits=lx/r^2?
Most of lux meters have a milky-color hemispherical caps to make them insensitive to direction of arrival of light. Ideally, such caps have a 2pi steardian FOV, but cheap meters may have a reduced FOV.
Candela reading of meter is generated just by dividing lux reading of meter by its FOV.
As long as your light source (monitor) is fully in the FOV of meter, will be no loss of accuracy by using either lux or candela readout.
My understanding is that the candelas are a property of the source, and should be independent of the distance ##d## (as long as you remain in the same solid angle, as seen from the source). I think that what your device really measures is lux, and the candelas are computed from that as ## \text{lx} × d^2 ##. At twice the distance you should find 1/4 of the illuminance (lux).
I think this should be ## \text{candelas} / (\pi r^2) ##.
EDIT: I would dispense with the circular aperture, and use ## \text{candelas} / (A \cos \theta) ## to get the average nits of the screen of size ##A##, assuming a big enough distance and possibly seeing it inclined at an angle ##\theta##.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
