MHB -m30b Convert the differential equation
karush
MHB
ov!347 nmh{1000}
$$y''+5y'+6y=e^x$$
into a system of first order (nonhomogeneous) differential equations and solve the system.
the characteristic equation is
$$\lambda^2+5\lambda+6=e^x$$
factor
$$(\lambda+2)(\lambda+3)=e^x$$
ok not real sure what to do with this $=e^x$ thing
$$y''+5y'+6y=e^x$$
into a system of fi rst order (nonhomogeneous) differential equations and solve the system.
factor
The characteristic equation is [math]\lambda ^2 + 5 \lambda + 6 = 0[/math]. You don't need the [math]e^x[/math] until later.
-Dan
$(\lambda+2)(\lambda+3)=0$
the root are then
$\lambda-2, \quad \lambda-3$
so then we have
$e^{-2x},\quad e^{-3x} $
then hopefully
$y=c_1e^{-2x}+c_2e^{-3x}$
so how do we finish this ? with =e^x
the root are then
so then we have
then hopefully
I was commenting on what the characteristic equation is, not what you are supposed to do for this problem.
Let's define A(x) = y(x) and B(x) = y'(x). Then
A'(x) = y'(x)
B'(x) = y''(x)
Putting this into your original equation gives
[math]y'' = -5y' - 6y + e^x[/math]
or
[math]B' = -5B - 6A + e^x[/math]
And don't forget: [math]A' = B[/math], from the original definition of B.
So you have the system of differential equations:
[math]\left ( \begin{matrix} A' \\ B' \end{matrix} \right ) = \left ( \begin{matrix} B \\ -6A - 5B \end{matrix} \right )+ \left ( \begin{matrix} 0 \\ e^x \end{matrix} \right )[/math]
or, using the usual notation:
[math]\left ( \begin{matrix} A \\ B \end{matrix} \right ) ^{\prime} = \left ( \begin{matrix} 0 & 1 \\ -6 & -5 \end{matrix} \right ) \left ( \begin{matrix} A \\ B \end{matrix} \right ) + \left ( \begin{matrix} 0 \\ e^x \end{matrix} \right )[/math]
Now you have a pair of simultaneous first order linear differential equations, which you've been studying.
-Dan
$$y''+5y'+6y=e^x$$
This first part has not been addressed. Let z= y'. Then y''= z'.
Then $z'+ 5z+ 6y= e^z$ or $z'= e^x- 5z- 6y$. Together with z= y' we have the two equations y'= z and $z'= e^x- 5z- 6y$.
That could also be written as the matrix equation
$\begin{pmatrix}y \\ z \end{pmatrix}'= \begin{pmatrix}0 & 1 \\ -6 & -5 \end{pmatrix}\begin{pmatrix}y \\ z \end{pmatrix}+ \begin{pmatrix} 0 \\ e^x\end{pmatrix}$.
The characteristic equation for the differential equation is the characteristic equation for that matrix, $\left|\begin{array}{cc}-\lambda & 1 \\ -6 & -5- \lambda\end{array}\right|= 0$.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
