Mag 7.8, 7.5, 6.7 and 6.0 earthquakes and aftershocks in Turkey
  • Thread starter Thread starter Astronuc
On February 6, 2023, Turkey experienced a series of devastating earthquakes, including a major 7.8 magnitude quake, resulting in significant destruction and a rising death toll that has surpassed 34,179 across Turkey and Syria. The earthquakes, which struck near the East Anatolian Fault, were felt in neighboring countries and caused widespread building collapses, trapping many individuals under rubble. Rescue efforts have been hampered by cold weather and ongoing aftershocks, leading to fears that many trapped survivors may not survive. The infrastructure in affected areas is severely damaged, with shortages of food and water reported. The earthquakes have prompted investigations into construction practices, as many buildings were not designed to withstand such strong tremors. The region is known for its seismic activity due to the complex interactions of the Africa, Arabia, and Eurasia tectonic plates, making future seismic events a concern.
Astronuc
Staff Emeritus
M 7.8 - Central Turkey - https://earthquake.usgs.gov/earthquakes/eventpage/us6000jllz/executive
  • 2023-02-06 01:17:35 (UTC)
  • 37.174°N 37.032°E
  • 17.9 km depth
M 7.5 - 4 km SSE of Ekinözü, Turkey - https://earthquake.usgs.gov/earthquakes/eventpage/us6000jlqa/executive
  • 2023-02-06 10:24:49 (UTC)
  • 38.024°N 37.203°E
  • 10.0 km depth
M 6.7 - Central Turkey - https://earthquake.usgs.gov/earthquakes/eventpage/us6000jlm1/executive
  • 2023-02-06 01:28:15 (UTC)
  • 37.127°N 36.943°E
  • 14.5 km depth
M 6.0 - 5 km NE of Göksun, Turkey - https://earthquake.usgs.gov/earthquakes/eventpage/us6000jlrc/executive
  • 2023-02-06 12:02:11 (UTC)
  • 38.061°N 36.537°E
  • 10.0 km depth
Four strong earthquakes all fairly shallow.
Off the south coast of Pakistan and southeast coast of Iran, the Makran trench is the present-day surface expression of active subduction of the Arabia plate beneath the continental Eurasia plate, which converge at a rate of approximately 20 mm/yr. Although the Makran subduction zone has a relatively slow convergence rate, it has produced large devastating earthquakes and tsunamis. For example, the November 27, 1945 M8.0 mega-thrust earthquake produced a tsunami within the Gulf of Oman and Arabia Sea, killing over 4,000 people. Northwest of this active subduction zone, collision of the Arabia and Eurasia plates forms the approximately 1,500-km-long fold and thrust belt of the Zagros Mountains, which crosses the whole of western Iran and extends into northeastern Iraq. Collision of the Arabia and Eurasia plates also causes crustal shortening in the Alborz Mountains and Kopet Dag in northern Iran. Eastern Iran experiences destructive earthquakes that originate on both strike-slip and reverse faults. For example, the 16 September 1978 M7.8 earthquake, along the southwest edge of the Dasht-e-Lut Basin killed at least 15,000 people.
Along the eastern margin of the Mediterranean region there is complex interaction between the Africa, Arabia and Eurasia plates. The Red Sea Rift is a spreading center between the Africa and Arabia plates, with a spreading rate of approximately 10mm/yr near its northern end, and 16mm/yr near its southern end (Chu, D. and Gordon, R. G., 1998). Seismicity rate and size of earthquakes has been relatively small along the spreading center, but the rifting process has produced a series of volcanic systems across western Saudi Arabia.
Further north, the Red Sea Rift terminates at the southern boundary of the Dead Sea Transform Fault. The Dead Sea Transform is a strike-slip fault that accommodates differential motion between the Africa and Arabia plates. Though both the Africa plate, to the west, and the Arabia plate, to the east, are moving in a NNE direction, the Arabia plate is moving slightly faster, resulting in the left-lateral, strike-slip motion along this segment of the plate boundary. Historically, earthquake activity along the Dead Sea Transform has been a significant hazard in the densely populated Levant region (eastern Mediterranean). For example, the November 1759 Near East earthquake is thought to have killed somewhere between 2,000-20,000 people. The northern termination of the Dead Sea Transform occurs within a complex tectonic region of southeast Turkey, where interaction of the Africa and Arabia plates and the Anatolia block occurs. This involves translational motion of the Anatolia Block westwards, with a speed of approximately 25mm/yr with respect to Eurasia, in order to accommodate closure of the Mediterranean basin.
The right-lateral, strike-slip North Anatolia Fault, in northern Turkey, accommodates much of the westwards motion between the Anatolia Block and Eurasia Plate. Between 1939 and 1999, a series of devastating M7.0+ strike-slip earthquakes propagated westwards along the North Anatolia Fault system. The westernmost of these earthquakes was the 17th August 1999, M7.6 Izmit earthquake, near the Sea of Marmara, killed approximately 17,000 people.
At the southern edge of the Anatolia Block lies the east-west trending Cyprian Arc with associated levels of moderate seismicity. The Cyprian Arc represents the convergent boundary between the Anatolia Block to the north and the Africa Plate to the south. The boundary is thought to join the East Anatolia Fault zone in eastern Turkey; however no certain geometry or sense of relative motion along the entire boundary is widely accepted.
https://earthquake.usgs.gov/earthquakes/eventpage/us6000jllz/region-info
https://earthquake.usgs.gov/earthquakes/eventpage/us6000jllz/map
  • Sad
Likes pinball1970, Twigg, Wrichik Basu and 2 others
Likes pinball1970
Death toll from Turkey earthquake rises to more than 3,400! The number was 2800 when I first read the article, and it was quickly updated.
ADANA, Turkey (AP) — A powerful 7.8 magnitude earthquake rocked wide swaths of Turkey and neighboring Syria on Monday, killing more than 2,800 people and injuring thousands more as it toppled thousands of buildings and trapped residents under mounds of rubble.
Authorities feared the death toll would keep climbing as rescuers searched through tangles of metal and concrete for survivors in a region beset by Syria’s 12-year civil war and a refugee crisis.
https://apnews.com/article/earthquake-shakes-turkey-b927808f6a5c54bdb669120faa40b7bc
  • Wow
  • Sad
Likes pinball1970, BillTre and Wrichik Basu
Astronuc said:
Death toll from Turkey earthquake ...
from: https://www.nbcnews.com/news/world/live-blog/earthquake-turkey-syria-live-updates-rcna69449
In Turkey, at least 5,434 people were killed and 22,168 injured, according to Turkish President Recep Tayyip Erdogan. Some 8,000 people have been rescued from the rubble. In Syria, at least 812 people were killed, with another 1,832 injured, in the affected areas, according to the Syrian Health Ministry.
edit:
This report is now saying 6,000 deaths:
The death toll of two devastating earthquakes that struck Turkey and Syria has surpassed 6,000 in addition to 10,000 people injured NBC News' Matt Bradley reports on ho rescue workers fear survivors trapped will not outlive cold temperatures and aftershocks throughout the night.
  • Sad
Likes pinball1970, Wrichik Basu and Astronuc
This won't be the last word. They still miss 8,000 people in Turkey alone and the area is so big that I expect a death toll about 20,000 if everyone is found / counted. If I look at the pictures now, I can only hope that I will not experience the campi flegrei in my lifetime. It will happen for sure, same as the one in Turkey and Syria was overdue in that area. Everybody Every seismologist knew ...
I looked at the area last night and noticed a large number of aftershocks in the Taurus Mountain range, as well as in the area between two faults along the coast of Syria. It would be interesting to know how much vertical displacement and/or lateral displacement has occurred in those areas. I also wonder what this means for future activity along the fault lines, and should we expect similar activity from Greece through Iran in the near (next several years/decades) future. In rural areas and small cities, I suspect the buildings were neither designed nor constructed for such strong earthquakes. Given the experience of the last several decades from Greece/Aegean through Iran, such earthquakes should be expected.
I've attached some screenshots from USGS Latest Earthquakes: one from last night and three from today.
Likes pinball1970 and dlgoff
dlgoff said:
I heard a story on NPR of a woman who gave birth during the earthquake. She and her husband were killed when the building in which they lived collapsed, but the newborn baby was rescued by a relative and taken to a nearby hosptial.
Edit/Update: The newborn and parents are/were from Syria.
https://www.yahoo.com/news/newborn-umbilical-cord-intact-rescued-210654602.html
The baby's mother, father, four siblings and an aunt were all killed, the cousin said, according to AFP. :frown::cry:
  • Sad
  • Wow
Likes pinball1970, dlgoff and Wrichik Basu
fresh_42 said:
This won't be the last word. They still miss 8,000 people in Turkey alone and the area is so big that I expect a death toll about 20,000 if everyone is found / counted. If I look at the pictures now, I can only hope that I will not experience the campi flegrei in my lifetime. It will happen for sure, same as the one in Turkey and Syria was overdue in that area. Everybody knew ...
Very very sad. I can't imagine being in something like that. However back when I when I was in college studying at home, pencils in a glass shock around from a trimmer in Oklahoma.
Dang. Every time I look at that site https://www.nbcnews.com/news/world/live-blog/earthquake-turkey-syria-live-updates-rcna69449, the count goes up
Now it is called Kahramanmaras earthquake(s)
https://www.nbcnews.com/news/world/live-blog/earthquakes-turkey-syria-live-updates-rcna69647
  • The death toll from Monday's devastating earthquakes has soared past 11,000 and is expected to rise.
  • The temblor has become the deadliest since Japan’s 9.0-magnitude quake in 2011 sparked a triple catastrophe that left more than an estimated 20,000 people dead.
The death toll has risen to 11,719 today.https://www.bbc.com/news/science-environment-64540696
  • Sad
Likes pinball1970
@Astronuc
There are many videos out there. I need to stop watching them. :oldcry:
Likes pinball1970
Earthquakes are diminishing, with the strongest being Mag 4.8 in the last 24 hours.
The earthquakes occurred along the East Anatolian Fault
https://en.wikipedia.org/wiki/East_Anatolian_Fault#/media/File:Anatolian_Plate_Vectoral.svg
https://www.nytimes.com/interactive/2023/02/06/world/turkey-earthquake-faultlines.html
Death toll exceeds 19000, and three days after the devastating quake, the death toll in Turkey and Syria neared 20,000.
https://www.nytimes.com/live/2023/02/09/world/turkey-syria-earthquake
Likes pinball1970
[Sigh]
Anti-nuclear bias so deep-seated I doubt they even recognize it:
USA Today said:
Earthquake death toll over 19,300, surpassing that of Japan's Fukushima disaster
That's USA Today's current headline.
"The Fukushima disaster" was the Fukushima nuclear plant meltdown, which killed potentially a handful of people (one confirmed I think). It was triggered by the "Tohuku earthquake and tsunami", which is what killed 18-20k (source dependent).
Edit, 2/10, CNN now has basically the same headline, same phrasing: "Japan's Fukushima disaster".
Likes pinball1970 and Astronuc
Terrible images.
Also, desperate families fleeing from war in Syria find refuge in Turkey then this.
Glad resources are getting over there quickly from the UK, people and kit.
  • Sad
Likes pinball1970
Astronuc said:
Death toll now exceeds 23K.
Large and long fissures have been reported in the region. Reuters reports that Turkey earthquake drone footage shows fissures slicing through land.
https://www.yahoo.com/news/turkey-earthquake-drone-footage-shows-171558428.html (subscription may be required for the full article).
https://www.reuters.com/news/picture/turkey-earthquake-drone-footage-shows-fi-idUSKBN2UK1L5
https://www.trtworld.com/turkey/türkiye-quakes-drone-footage-shows-fissures-slicing-through-land-65334
Workers still working in those areas with aftershocks?
EDIT: Of course, stupid question. Risking their lives to save people as soon as this happened.
  • Sad
Likes pinball1970
Astronuc said:
Apparently so.
https://www.cnn.com/middleeast/live-news/turkey-syria-earthquake-updates-2-11-23-intl/index.html
People are still being rescued from the rubble.
Death toll exceeds 25K:
In Turkey, the number of people killed has risen to 21,848, according to Turkish President Recep Tayyip Erdogan.
In Syria, the total number of deaths stands at 3,553.
Looking at the construction and contractors now to see what has been skipped. https://www.google.com/amp/s/amp.th...ding-contractors-earthquake-death-toll-mounts
pinball1970 said:
Looking at the construction and contractors now to see what has been skipped.https://www.google.com/amp/s/amp.th...ding-contractors-earthquake-death-toll-mounts
Yes, I heard interviews with Turkish and Syrian authorities and doctors.
Turkey detains building contractors as the quake death toll rises to more than 33,000​
One doctor in Idlib, Syria was actually living in Turkey, but his home is destroyed and he wants to help folks, so he's living at the hospital in Idlib, while he wife and son are back in Turkey living with someone (a friend?).
From yesterday - https://www.npr.org/2023/02/11/1155955553/turkey-earthquake-gaziantep-displaced-people
The infrastructure in southern Turkey and northern Syria is destroyed or severely damaged. Food and water are in short supply, so thousands of structures are destroyed, or damaged to the point of being uninhabitable.
https://www.cnn.com/2023/02/11/middleeast/turkey-syria-earthquake-recovery-intl
Good graphic showing locations of aftershocks and the major 7.8 and 7.5 earthquakes.
The death toll across Turkey and Syria following Monday’s catastrophic earthquake has reached at least 34,179 on Sunday.
The death toll in Turkey has reached 29,605, Turkish Emergency Coordination Center SAKOM said Sunday.
The confirmed death toll in Syria is 4,574. That number includes more than 3,160 in opposition-held parts of northwestern Syria, according to the health ministry of the Salvation Government governance authority.
The Syrian death toll also includes 1,414 deaths in government-controlled parts of Syria, according to state news agency SANA.
https://www.cnn.com/middleeast/live...12-23-intl/h_30c82a9cc029ddf81ff25fab3582348a
  • Sad
Likes pinball1970
pinball1970 said:
They do not expect to find anyone alive now according to your link.
People who survived the quakes now have the cold and lack of food and water to deal with.
Temperatures freezing at night looking at forcasts.
https://www.cnn.com/middleeast/live...13-23-intl/h_41126da165b68e7c6314a46b331bc725
Edited/revised: Seven days after the devastating magnitude 7.8 earthquake struck Turkey and Syria, teams are still finding victims that are alive. One survivor is Huseyin Berber.
The rescue operation took place at Mimar Sinan street of Antakya. Berber was immediately taken to a hospital, Anadolu reported. Berber's rescue followed the discovery of a 13-year-old boy in Hatay.
Death toll 31,643 in Turkey, more than 5,700 in Syria = 37343
https://www.reuters.com/world/middl...er-earthquake-rubble-turkey-syria-2023-02-12/
Likes pinball1970
A verdant olive grove was cleaved into two during last week’s devastating earthquake in Turkey, creating a valley 984 feet long (about 300 meters) that now divides the area.
Remarkable footage of the split olive grove has emerged from Turkey’s south-east Altınozu district, which borders Syria, showing a jagged, sandy-colored, canyon-like chasm. The cleavage reaches over 130 feet deep (40 meters).
Its creation is another show of the devastating power of last Monday’s magnitude 7.8 quake, which killed tens of thousands of people in Syria and Turkey and destroyed entire city blocks.
https://www.cnn.com/2023/02/14/middleeast/turkey-olive-grove-split-earthquake-intl/index.html
Last Monday’s earthquake was the strongest to hit anywhere in the world since an 8.1 magnitude quake struck a region near the South Sandwich Islands in the southern Atlantic Ocean in 2021, though the remote location of that incident resulted in little damage.
Turkey is no stranger to strong earthquakes, as it is situated along tectonic plate boundaries. Seven quakes with magnitude 7.0 or greater have struck the country in the past 25 years – but last Monday’s was its most deadly.
  • Wow
Likes pinball1970
  • #31
dlgoff said:
This image ... blows my mind:
The wall shown is blocky, not slick or scarred, so it looks like it failed in tension, not as the surface expression of a vertical shear fault.
What appears to have happened is a solid landslip. A large block of sedimentary rock on a hillside with a similar slope to the bedding, slid down-slope on an incompetent mudstone layer, leaving that precipice as the headwall.
The rock slide event was triggered by the earthquake. The foot of the rock slide is not shown. If the block was wedge shape, then the foot of the slide may be insignificant.
Likes davenn, dlgoff and BillTre
  • #32
M 6.3 - 3 km SSW of Uzunbağ, Turkey​
https://earthquake.usgs.gov/earthquakes/eventpage/us6000jqcn/executive
  • 2023-02-20 17:04:29 (UTC)
  • 36.109°N 36.017°E
  • 16.0 km depth
(CNN) – A magnitude 6.3 aftershock struck southern Turkey on Monday, two weeks after a massive earthquake killed tens of thousands of people in Turkey and Syria.
The quake struck Turkey’s southern Hatay province, near the Syrian border, Turkey’s Disaster and Emergency Management Agency (AFAD) said Monday.
The United States Geological Survey (USGS) initially reported the quake as being of magnitude 6.4 at a depth of 10 kilometers before revising it down to 6.3 magnitude.
https://www.yahoo.com/news/magnitude-6-3-aftershock-rocks-143100286.html
That aftershock was accompanied by two smaller quakes of 4.2 (nearest) and 4.1 (further to the NNE). Further north were a 4.3 mag quake in Kahramanmaras province and a 4.1 mag quake in the mountains of Malatya province.
  • Sad
Likes pinball1970
