Magentic induction and shielding
In summary, when a ferro-magnetic material is placed near a magnet, induced magnetism occurs. If the material is compressed into a thin sheet, electromagnetic shielding occurs. In the first situation, an iron pin will be attracted to the induced iron, but in the second situation, the iron pin will not be attracted due to the shielding of the magnetic field. The difference between a bar and a sheet of iron is the length of the material, which affects the occurrence of induced magnetism or electromagnetic shielding.
serverxeon
101
This happens when the ferro-magnetic material is placed near to the magnet. (call this induced magnetism)
BUT
if the bar shape ferro-magnetic material's length is compressed into as thin as a sheet of iron,
Electromagnetic shielding occurs.
In the first situation, an iron pin will be attracted by the induced iron, but in the second situation, the iron pin will not be attracted.
I do not understand why will there be two occcurance, and how to classify any situation to know which will occur.
What "pin" are you talking about? In the first case you have a bar of iron that is attracted to the magnet. In the second you flatten the iron into a sheet which will also be attracted to the magnet. I see no "pin" in either case.
the pin is not in the picture
imagine a pin approach the iron bar, or sheet in both cases, from the right.
From what i was told, the magnetic field will flow through the iron bar, therefore magnetising it. (so the pin will be attracted to the iron bar)
But, in the case of a the iron sheet, the magnetic field is diverted(shielding), and anything belhind will not experience magnetism from the magnet. (the pin does not feels any attraction)
what difference is there between a sheet and a bar magnet? isn't it just the 'length' of that piece of iron? why are there 2 different results?
FAQ: Magentic induction and shielding
What is magnetic induction?
Magnetic induction is the process by which a magnetic field is created in a material, usually by exposing it to a changing magnetic field. This causes the material to become magnetized and have its own magnetic field.
How does magnetic shielding work?
Magnetic shielding is a method used to block or reduce the strength of a magnetic field. This is typically achieved by surrounding the area or object with a material that is highly permeable to magnetic fields, such as iron or steel.
What are some applications of magnetic shielding?
Magnetic shielding is used in a variety of industries and applications. Some examples include shielding sensitive electronic equipment from magnetic interference, creating MRI machines for medical imaging, and protecting astronauts from space radiation in spacecrafts.
Can magnetic shielding be used to protect against all types of magnetic fields?
No, magnetic shielding is most effective against static or low-frequency magnetic fields. It becomes less effective against high-frequency or rapidly changing magnetic fields.
Are there any potential health risks associated with magnetic shielding?
While magnetic shielding itself is not harmful, the materials used for shielding may pose health risks if not properly handled or disposed of. Additionally, if magnetic shielding is used to block a magnetic field that is necessary for the functioning of certain devices, it may cause malfunctions or damage to the equipment.
