- #36
- 24,492
- 15,025
I don't know which return wire you are talking about. Of course, the naive limit of zero resistance doesn't make any sense. If you want to treat the problem for a superconducting pipe, you have to employ the correct constitutive relations as for any material, i.e., on the classical level you have to use the London equationsOrthoceras said:An excellent video, except that it does not explicitly address the special case that I was asking about in my opening post, the case where both the pipe and the return wire (the wire connecting top and bottom of the pipe) have zero resistance. ("Does zero resistance affect the terminal speed of the magnet?") In the case of zero resistance, the average vertical speed of the electrons in the pipe is arbitrary, while the copper atoms are stationary. Then the velocity v from the formula F = k v, in the video at t=21:10, is the difference between the vertical velocity of the magnet and the vertical velocity of the electrons (not the copper atoms). This allows the magnet to fall down to the bottom of the pipe, its lowest energy level.
https://en.wikipedia.org/wiki/London_equations
