Magnet moved in a circular coil
In summary, the conversation discusses the effects of a moving magnet on a coil, including the change in flux, induced EMF, and resulting current. The group also discusses the relationship between the induced current and the frequency of movement, as well as how a galvanometer would react in different scenarios. Ultimately, they conclude that option 3) is the most likely answer for this exercise.
Jahnavi
848
102
As the magnet moves in and out of the coil , flux linked with the coil changes , as a result an EMF is induced in the coil . A current flows in the coil . The current depends on how fast the magnet is moved . Current will vary in the coil . I think Options 1) and 4) can be ignored .
I don't understand how the induced current depends upon the frequency with which magnet is moved .
How do we choose between 2) and 3) ?
Hi,
Good work so far. Choosing between 2 and 3 means finding something that has to do with frequency. The composer (deliberately?) complicated the issue by using the term voltmeter.
What is the form of the induced EMF, as e.g. expressed in terms of a function ##V(t)## ?
Hi ,
Let us assume that it is a printing mistake . Please read voltmeter as Galvanometer .
It is dΦ/dt or AdB/dt i.e area (of the coil) times rate of change of magnetic field through the coil .
Yes, so quickly varying (like e.g. a sine) at 50 Hz and slowly at 1 or 2 Hz. With an amplitude proportional to the frequency. What would a galvanometer show in case 2 ? And in case 3 ?
Likes Jahnavi
Why ?
Visible large variation . Option 2) says "small" variation .
I missed out on the word "small" given in the second option .
Option 2) can also be left out .
Jahnavi said:
Why ?
So a bigger signal in 2 than in 3.
Nevertheless:
No. The amplitude of the EMF may be a lot bigger than in 3, but the point is that a) the galvanometer can't follow that so fast, and even if it could, you wouldn't be able to follow it so fast.
Likes Jahnavi
Sorry .
Do you mean there will be a large variation in case of option 2) but it might not be visible . Is "visible" the issue in option 2) ?
The needle of Galvanometer will move to and fro from one side to other very quickly but it will be visible . I might be wrong .
50 Hz can't be followed by a mechanical galvanometer. So there won't be a large oscillation.
A modern intelligent multimeter would probably detect an AC signal and use a rectifier -- and show a voltage.
My money is on 3) for this exercise ('very sensitive galvanometer')
Likes Jahnavi
So , the needle of the Galvanometer more or less stays in its place ?
yes
Likes Jahnavi
Thanks !
Related to Magnet moved in a circular coil
What is a magnet moved in a circular coil?
A magnet moved in a circular coil is a setup where a magnet is rotated inside a coil of wire. This motion creates a changing magnetic field which induces an electric current in the coil.
How does a magnet moved in a circular coil generate electricity?
As the magnet moves through the coil, it creates a changing magnetic field. This changing magnetic field induces an electric current in the wire, which can then be captured and used as electricity.
What factors affect the amount of electricity generated by a magnet moved in a circular coil?
The amount of electricity generated depends on the strength of the magnet, the speed at which it is moved, the number of turns in the coil, and the resistance of the wire used in the coil.
What is the difference between a magnet moved in a circular coil and a regular generator?
A magnet moved in a circular coil is a simple setup that demonstrates how electricity can be generated from a changing magnetic field. A regular generator is a more complex machine that uses the same principle, but with multiple magnets and coils to produce a larger amount of electricity.
What are some real-world applications of a magnet moved in a circular coil?
A magnet moved in a circular coil is used in devices such as electric motors, generators, and transformers. It is also used in some forms of renewable energy, such as wind turbines and hydroelectric power plants.
