I Magnetar Mystery: How Do Neutrons Generate a Magnetic Field?
Neutrons in a magnetar, despite having no charge, possess an intrinsic magnetic moment, which contributes to the star's magnetic field. The magnetic field of a magnetar is also inherited from the progenitor star that underwent a supernova, becoming concentrated due to the neutron star's smaller size. Additionally, neutron star cores contain a mix of electrons and protons, which can influence the magnetic properties. Initially, a geodynamo may have existed in the early neutron star, but this ceases once the core cools and becomes superconductive. Overall, the generation of a magnetic field in magnetars involves both intrinsic properties of neutrons and the remnants of the original star's magnetic field.
swampwiz
If a magnetar is a neutron star, how do the neutrons composing the star generate a magnetic field? A neutron has zero charge, so it generates no magnetic field.
Astronomy news on Phys.org
Neutron star cores contain a percentage of electrons and protons. I've seen estimates as high as ten percent.
However the magnetic field is inherited from the star that went supernova. Magnetic fields are remarkably persistent. The neutron star is far smaller than the original star so the magnetic field becomes very concentrated.
In the case of a magnetar, there was a short-lived geodynamo in the early days of the neutron star. Once the core is cool enough to be superconductive, there are no more convection currents and hence no more geodynamo. I haven't looked at these things for 15 years so I might not remember it correctly, that's the best I can do.
That's not true. Neutrons have an intrinsic magnetic moment, though I'm unsure if this contributes to a magnetar's magnetic field or not. See here: https://en.wikipedia.org/wiki/Neutron_magnetic_moment
Likes Dragrath and SammyS
Not true. A neutron has a magnetic moment - i.e. is a little magnet in and of itself.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
