Magnetic and Electric Fields problem
In the discussion about magnetic and electric fields, participants explore the relationship between gravitational force and magnetic force acting on a wire. The main focus is on determining the conditions under which a wire carrying a 40 A current can "float" in a magnetic field generated by another wire. To achieve this, the required magnetic field strength (B) is calculated first, followed by the necessary current in the stationary wire to produce that magnetic field at a specific distance. Oersted's law is referenced to explain the principles at play in this scenario. The conversation emphasizes the calculations needed to balance gravitational and magnetic forces for the wire to remain suspended.
davidj
A straight wire of linear mass density 150 g/m has a
current of 40.0 A (supplied by a flexible connection of
negligible mass). This wire lies parallel to, and on top
of, another straight horizontal wire on a table. What
current must the bottom wire have in order to repel
and support the top wire at a separation of 4.0 cm
fg = mg
fm = qvbsin(theta)
BIL = mg
Would i assume that fg = fm (force gravity holding straight wire down is equal to the magnetic force) and isolate for I?
Help if you're available please!
Are you familiar with Oersted's law?
yes i am but how you mind explaining how its applicable in this situation
The wire that is supposed to "float" is subjected to the magnetic field that comes from the wire that is lying on the table.
First, calculate what B is required for the wire with 40 A current to "float". Then you figure out what current is required in the cable lying on the table to produce this magnetic field at the desired distance.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
