shushi_boi
- 45
Hello everyone from the Physics Forums, I'm doing a school project and I'm looking for a potential anode alloy that is ferromagnetic which I could use with a copper cathode. I'm making a battery and I have to use copper as my cathode mainly because I have made the cathode cells structured similar to a squirrel cage because I want to test its design when induced with chemical and magnetic reactions (its a weird idea but I'm more than welling to report my results to anyone whose curious). And I also what to have a material that will react with copper more than iron because the casing will contain iron and I don't want the iron to react with the anode and cathode reactions (because it is part of the housing and also because the the copper cells have iron cores to help attract and induce the magnetic fields.
I have found a list of soft and permanent magnets online but I was very fascinated with having a costume made ferrite magnet made from
epsilon iron(III) oxide ε-Fe2O3 because this oxide is highly magnetic and it also has an oxide agent which in turn is desirable for an anode agent (just an idea of mine, testing with my limited funds).
Here is the list of some permanent magnets that I found online and their chemical composition, if anyone has any ideas I'm open up to any of them and if you need more information you may ask away!BaFe12O19
Barium-Iron Oxide
Alnico IV
Al-Ni-Co
12%-27%-5%
Alnico V
AlNiCo5
Al-Ni-Co-Cu-Fe
8%-14%-24%-3%-48%
Alcomax I
MnBi
Manganese- Bismuth
Ce(CuCo)5
Cerium-copper-cobalt
SmCo5
samarium-cobalt
Sm2Co17
samarium-cobalt
Nd2Fe14B
neodymium
Bismanol
BIMn,( N=2–20,M=0–7)
Bi5Mn3
Bi9Mn4
Bi10Mn5
Bi12Mn6
Chromium(IV) oxide
CrO2
ToughNEO™
(Nd , Pr)16.5Dy0.5Fe76(Nb , Ga , Al , Cu , Mn , Ti)1B6Al-Ni-Co-Cu-Fe
8%-14%-24%-3%-48%
http://www.jlcelectromet.com/alloys.htm
Fe-Ni
20%- 80%
Ni - Mo - Fe
79%-5%-16%
Mu-metal
Nickel-iron-copper&molybdenum
75%-15%-10% (high permeability, shield magnets)
Heusler alloy Cu2MnAl
Cu2MnIn
Cu2MnSn,
Ni2MnAl
Ni2MnIn
Ni2MnSn
Ni2MnSb
Co2MnAl
Co2MnSi
Co2MnGa
Co2MnGe
Pd2MnAl
Pd2MnIn
Pd2MnSn
Pd2MnSb
Fe-Ni-Co
54Fe-29Ni-17Co
Ni – Co – Mn – Si – C – Fe
25-32% _ 10-15% _ 0.1-2% _ 1% _ 0.001-0.5% _ and the Rest%
Fernico
Ni – Co – Fe
31%-15% – Rest %
Cunife
1 = Cu – Ni – Fe
60% – 20% – 20 %
2 = Cu – Ni – Co – Fe
60% – 20%- 2.5% – 17.5%
Gallium manganese arsenide
(Ga,Mn)As
(Ga – Mn) – As
31%-15% – Rest %
Metglas
FeBSiC (a metastable amorphous alloy)
Fe – B – Si – C
80% – The rest balanced %
Permalloy
Fe – Ni
20%-80%
Sendust
Fe – Si – Al
85% – 9% – 6 %Yttrium Iron garnet
Y3Fe2(FeO4)3, or Y3Fe5O12
Ni – Co – Fe
31% -15% – Rest %
Barium-Iron Oxide
Alnico IV
Al-Ni-Co
12%-27%-5%
Alnico V
AlNiCo5
Al-Ni-Co-Cu-Fe
8%-14%-24%-3%-48%
Alcomax I
MnBi
Manganese- Bismuth
Ce(CuCo)5
SmCo5
samarium-cobalt
Sm2Co17
samarium-cobalt
Nd2Fe14B
neodymium
Bismanol
Bi5Mn3
Bi9Mn4
Bi10Mn5
Bi12Mn6
Chromium(IV) oxide
CrO2
ToughNEO™
8%-14%-24%-3%-48%
Fe-Ni
20%- 80%
Ni - Mo - Fe
79%-5%-16%
Mu-metal
Cu2MnIn
Cu2MnSn,
Ni2MnAl
Ni2MnIn
Ni2MnSn
Ni2MnSb
Co2MnAl
Co2MnSi
Co2MnGa
Co2MnGe
Pd2MnAl
Pd2MnIn
Pd2MnSn
Pd2MnSb
Fe-Ni-Co
54Fe-29Ni-17Co
Fernico
Ni – Co – Fe
31%-15% – Rest %
Cunife
1 = Cu – Ni – Fe
60% – 20% – 20 %
(Ga,Mn)As
(Ga – Mn) – As
31%-15% – Rest %
Metglas
Fe – B – Si – C
Permalloy
Fe – Ni
20%-80%
Sendust
Fe – Si – Al
Ni – Co – Fe
31% -15% – Rest %
