Magnetic energy inside a coaxial cable
The discussion focuses on calculating the magnetic energy inside a coaxial cable using Ampere's law. The magnetic field equations for different regions are established, with specific attention to the areas where the radius is less than the inner radius, between the inner and outer radii, and beyond the outer radius. Participants clarify the need to compute the energy stored in the magnetic field for each region separately, leading to the conclusion that the total energy is the sum of energies from both regions. There is some confusion about the constants and factors in the equations, but ultimately, the calculations are deemed correct. The conversation emphasizes the importance of accurately defining regions and integrating the magnetic field values appropriately.
happyparticle
##E_b = \frac{1}{2\mu_0} \int\int\int B^2 dv##
Hi,
I have to find the magnetic energy inside a coaxial cable of inner radius ##a## and outer radium ##b##, ##I = I##
By using Ampere's law
if ##r<a##
##B = \frac{\mu_0Ir}{2\pi a^2}##
if ##a<r<b##
##B = \frac{\mu_0I}{2\pi r}##
if ##r>b##
##B = 0##
Then, the energy in a magnetic field ##E_b = \frac{1}{2\mu_0} \int\int\int B^2 dv##
Since I have 2 different ##B## inside the cable, I'm not sure how to use this formula.
Your fields inside and out have different units. You should worry.
Likes happyparticle
I'm not sure to understand. Of course the fields inside and out have different units since ##B = 0## if ##r>b##
Is ##E_{tot} = E_{b1} + E_{b2}##
For example,
if ##a<r<b## and for a length = l
##E_{b1} = \frac{\mu_0 I^2 l}{4\pi} \cdot ln\frac{b}{a}##
I see you have corrected it. Good.
All right, but is it correct to say that ##E_{tot} = E_{b1} + E_{b2}##
What is ##b_1## ? ##b_2##? You need the integral as defined (notice ##B^2##). You will need to divide up the integral and use the value for B in each region.
I have to find the energy stored by the magnetic field.
##b_1## is the magnetic field where ##r<a## and ##b_2## is the magnetic field where ##a<r<b##
So, I would like to know If I have to find ##E_b## in each region?
Oh, I see, yes you do. So there will be two (easy) integrals one for each region. You've already done the in between ...did you do r<a yet?
Likes happyparticle
You have also called the regions several different ways! And look at he constants in the energy.
I didn't notice, sorry.
Thus,
##E_{tot} = \frac{\mu_0 I^2 L}{4\pi}(\frac{1}{4} + ln(\frac{b}{a}))##
Does it makes sense?
##r<a##
##E_{b2} = \frac{\mu_0 I^2 L}{16\pi} ##
I think the units are correct (## \mu_0 ## is Henrys /m ) . Check the r<a it seems off by a factor of 2 to me.
Yeah I guess its right...up to you now!
All right, so my ##r<a## is not off by a factor of 4?
My original objection was incorrect. I haven't looked at this problem before and the 1/4 seems weird to me but I don't see anything wrong so call it good.
All right, I trust you more than I trust myself.
Thanks!
When it comes to Algebra, probably not a good decision on your part.
EDIT: sorry about the mix-up.
What you are describing is not a coax cable. Looks like it's just the outer conductor of a coax cable.
Assuming that and a current flowing through the conductor, use Ampere's law as you describe for a<r<b, then your volume integral.
(Question to you: what is the field 0<r<a?). An easy integration (think cylindrical coordinales).
Don't know what all the E fields are doing in the foregoing posts.
  • · Replies 26 ·
  • · Replies 23 ·
