Magnetic Field and neutral points
In summary, when determining the null or neutral points of a bar magnet, only the horizontal component of the Earth's magnetic field is taken into account because the field lines are usually at an angle with regard to the bar magnet. Additionally, the magnetic fields that "leap out" of the flat plane of the bar magnet are not considered due to the assumption that the bar magnet's field lies in one plane.
prasannab13
If Earth's magnetic field is considered as "B" ,then it has two components along horizontal and vertical.But while determining null or neutral points of a bar magnet only horizontal component of magnetic field is taken into consideration but not vertical component of magnetic field.Why?
The reason Earth's magnetic field has a horizontal and vertical component is because it is oriented at angle with regard to the bar magnet in most places on Earth. Generally, you choose the reference frame to be that of the plane of the lab bar magnet. Of course you can also do it the other way and say that the lab bar magnet has a horizontal and vertical component while Earth magnet is purely in one direction but that makes things more complicated.
In the UK, the field lines lie about 70 degrees with regard to the horizontal. So when you conduct an experiment to measure the Earth's magnetic field by finding the null points between bar magnet and Earth magnet, you are only finding the horizontal component of the Earth's magnetic field.
This brings up another question of why you do not consider the magnetic fields that "leap out" of the flat plane of the bar magnet. The reason for that is because in most cases you can consider the bar magnet to be sufficiently flat that its magnetic field lies only in one plane.
This is because the vertical component of Earth's magnetic field is relatively weak compared to the horizontal component. The horizontal component is responsible for the direction of a compass needle and is the dominant force in determining the behavior of a bar magnet. Therefore, when determining the neutral points of a bar magnet, the vertical component can be ignored as it does not significantly affect the overall magnetic field.
FAQ: Magnetic Field and neutral points
What is a magnetic field?
A magnetic field is a region in space where magnetic forces can be detected. It is created by moving electric charges, such as electric currents, and is characterized by its direction and strength.
How is a magnetic field measured?
A magnetic field is measured using a device called a magnetometer. This instrument can detect the direction and strength of a magnetic field and can be used to map out the shape and intensity of a magnetic field.
What are neutral points in a magnetic field?
Neutral points are locations within a magnetic field where the magnetic forces cancel out, resulting in a net magnetic force of zero. At these points, the magnetic field lines cross and form a complex pattern known as a neutral point network.
How are neutral points important in understanding the behavior of a magnetic field?
Neutral points play a crucial role in understanding the behavior of a magnetic field because they are areas of low energy and stability. They act as boundaries between regions of different magnetic strengths and can help scientists predict how a magnetic field will interact with other objects.
What applications do magnetic fields and neutral points have?
Magnetic fields and neutral points have various applications, including in compasses, motors, generators, and magnetic resonance imaging (MRI) machines. They are also important in understanding the behavior of the Earth's magnetic field and its impact on our planet.
