Magnetic field at a distance - epxression
In summary, the conversation discusses the need to find the pull force of a cylindrical Neodymium permanent magnet at various distances and whether there is an expression relating the force to the magnetic flux density and distance. The parameters for the magnet are provided and the conversation also mentions the possibility of using a magnetic dipole moment to approximate the force.
rsr_life
51
Hello,
I have a cylindrical Neodymium permanent magnet. I need to find the pull force of the magnet at various distances from the magnet. Is there an expression relating the pull force(or attractive force) to the magnetic flux density B and the distance from the cylindrical magnet? What is the expression that tells us how the B varies with distance?
The parameters I have for the magnet are here
http://www.kjmagnetics.com/proddetail.asp?prod=D2C .
Thanks,
rsr_life
The wiki doesn't seem to have an expression listed for calculating magnetic flux density at a distance for a cylindrical permanent magnet. There's no current involved, so I just want to be able to simulate and get field values at different points from the magnet.
Seems there should be a straightforward expression to do this, maybe involving partial derivatives.
Thanks.
Far enough away, most magnets can be approximated as a magnetic dipole moment m, which is a vector. For a magnetic dipole m at the origin and oriented in the z-direction, you get
[tex] \vec{B} = {\mu_o m \over {4\pi r^3}} (2\cos\theta \hat{r} + \sin\theta\hat{\theta})[/tex]
The trick for your problem will be to find out a good guess at m. As usual, Wikipedia has some good information.
Thanks for that. What about points closer to the magnet - near the surface, for example, where the gradient is steeper?
Maybe you can find an equation by experiment. Could you use some type of spring device (to messure weight) with a iron-mass on it and find the force at different points around the magnet? Say; leave the spring hanging and moving the magnet at different positions under the mass?
FAQ: Magnetic field at a distance - epxression
What is the equation for calculating the magnetic field at a distance?
The equation for calculating the magnetic field at a distance is B = μ0I/2πr, where B is the magnetic field strength, μ0 is the permeability of free space, I is the current, and r is the distance from the source of the magnetic field.
How does the distance from a magnetic source affect the strength of the magnetic field?
The strength of the magnetic field decreases as the distance from the source increases. This is because the magnetic field spreads out as it gets farther away, resulting in a weaker field at a greater distance.
What is the unit of measurement for magnetic field at a distance?
The unit of measurement for magnetic field at a distance is Tesla (T). Other commonly used units include Gauss (G) and microtesla (μT).
Can the magnetic field at a distance be negative?
No, the magnetic field at a distance cannot be negative. The direction of the magnetic field is determined by the direction of the current, and the magnitude is always positive.
How is the magnetic field at a distance related to the strength of the current?
The magnetic field at a distance is directly proportional to the strength of the current. This means that as the current increases, the magnetic field at a distance also increases. Similarly, as the current decreases, the magnetic field at a distance decreases.
