I Magnetic field at a point along the solenoid's axis but outside the solenoid
The discussion revolves around calculating the EMF induced by a solenoid when the secondary circuit for eddy currents is located outside the solenoid's length but still along its axis. The main challenge is determining the vector magnetic field inductance at this external point, as existing resources primarily address fields inside or outside the solenoid's radius. Participants suggest researching the magnetic field along the axis of a current loop and integrating the turns per unit length over the solenoid's length. A technical issue with LaTeX formatting was also addressed, which was resolved by correcting a missing bracket. The conversation highlights the complexity of magnetic field calculations in this specific configuration.
turo_loler
TL;DR Summary
For a personal project, I need to calculate the EMF induced by a solenoid, the problem is, that the secondary circuiit where the eddy currents are formed are outside the solenoid's length but on it's axis.
For a personal project, I need to calculate the EMF induced by a solenoid, the problem is, that the secondary circuit where the eddy currents are formed are outside the solenoid's length but still on it's axis.
The problem comes when i need to calculate the vector magnetic field inductance at a point outside the solenoid, i've been searching for quite a while but I have not managed to find an awnser, I just find keep finding that the net magnetic field vector due to ampere's law is near zero, but outsithe the radious of the solenoid, not ousithe the length of the solenoid
A graphical representation of my problem:
In Gaussian units, B is
$$B=\frac{2\pi nI}{c}\left[\frac{L/2-z}{\sqrt{(z-L/2)^2+a^2},
+\frac{(z+L/2)}{\sqrt{(z+L/2)^2+a^2}}\right]$$,
where ##n## is the number of turns per cm, ##I## is the current, ##a## is the radius, and ##z## is the distance along the axis from the center.
Why isn't latex working?
turo_loler said:
TL;DR Summary: For a personal project, I need to calculate the EMF induced by a solenoid, the problem is, that the secondary circuiit where the eddy currents are formed are outside the solenoid's length but on it's axis.
Google the magnetic field in axis of a current loop a distance ##z## from the loop (the off-axis field is moderately nasty but the on axis field is a simple expression). Then work out how many turns per unit length you have and integrate over the length of the solenoid.
You have unbalanced {} in the denominator of the first fraction inside the square brackets.
Likes Meir Achuz and turo_loler
$$B=\frac{2\pi nI}{c}\left[\frac{L/2-z}{\sqrt{(z-L/2)^2+a^2}}
It was a missing bracket in the first frac.
Perfect, just what i needed, thnks!
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
