Magnetic Field created from Current of Wire
In summary, to calculate the magnitude and direction of the magnetic field at a point 0.0346 m away from a current going into the page in the SW direction, you can use the formula B=μI/2∏r and determine the direction using the cross product B = I x r. To express the direction in terms of unit vectors \hat{i} and \hat{j}, you can use vector projection by finding the dot products of B with \hat{i} and \hat{j}, and then using the angle between the position vector and the axis. Remember to add or subtract 90 degrees to account for the direction of the magnetic field.
letsgo
So let's say I have a current, going into the page (that is, -[itex]\hat{k}[/itex]). And now let's say you're trying to figure out the magnitude and direction of the magnetic field 0.0346 m away from it, in the SW direction (45 degrees).
How would you calculate the answer in terms of unit vectors [itex]\hat{i}[/itex] and [itex]\hat{j}[/itex]?
I know these two formulas: B=μI/2∏r, and then to determine the direction of B= I x r, cross product.
So if I follow this, I get a B value of 7.63x10-6.
But this is where I get confused; finding the direction. I know, from drawing a diagram or even using B = I x r, cross product, that the direction is 45 degrees NW. But how would I express this in terms of unit vectors [itex]\hat{i}[/itex] and [itex]\hat{j}[/itex]?
You can do a vector projection of B onto the [itex]\hat{i}[/itex] and [itex]\hat{j}[/itex] directions.
So for the [itex]\hat{i}[/itex] direction you can just do [tex]B_{i} = \frac{\vec{B} \circ \hat{i}}{|\hat{i}|}[/tex]
and for the [itex]\hat{j}[/itex] direction you can do[tex]B_{j} = \frac{\vec{B} \circ \hat{j}}{|\hat{j}|}[/tex]
That gives you the value of the vector B in the direction you want ([itex]\vec{B} = <B_i, B_j, 0>[/itex]).
You can easily get the value of '[itex]\theta[/itex]' to use in the dot products in the numerators by using the angle between the position vector to the point who's magnetic field is in question and the axis in question. This would just be the '[itex]\theta[/itex]' for the position vector to the point, however, and not the magnetic field. Thus you need to add or subtract 90 degrees to the angle because the magnetic field is pointed 90 degrees away from the direction of the position vector.
FAQ: Magnetic Field created from Current of Wire
What is a magnetic field?
A magnetic field is a region in space where a magnetic force can be felt. It is created by the movement of electrically charged particles, such as the flow of current in a wire.
How is a magnetic field created from a current in a wire?
When an electric current flows through a wire, it creates a circular magnetic field around the wire. The direction of the magnetic field depends on the direction of the current flow, following the right-hand rule.
What factors affect the strength of the magnetic field created by a wire?
The strength of the magnetic field created by a wire depends on the amount of current flowing through the wire, the distance from the wire, and the material of the wire. Thicker wires with higher current and closer distance will create stronger magnetic fields.
What are some real-world applications of magnetic fields created from currents in wires?
Magnetic fields created by currents in wires are used in many devices, such as electric motors, generators, and speakers. They are also used in medical imaging techniques like MRI machines and in particle accelerators for scientific research.
Can magnetic fields created by currents in wires be harmful to humans?
In most cases, magnetic fields created by currents in wires are not strong enough to cause harm to humans. However, extremely strong magnetic fields, such as those found in MRI machines, can have adverse effects on pacemakers and other medical devices. It is important to follow safety guidelines and keep a safe distance from strong magnetic fields.
