Magnetic field due to a current carrying loop
In summary: This allows you to use Ampere's Law to find the magnetic field, as the symmetry of the system allows for easy integration. However, for asymmetrical systems, where the current does not have a simple path or direction, you cannot use Ampere's Law and must use the more general Biot-Savart Law. In summary, Ampere's Law is useful for high-symmetry systems, such as straight wires or solenoids, while Biot-Savart Law is more versatile and can be applied to asymmetrical systems.
ajay.05
46
The actual question was to somehow derive the expression for a magnetic field at the center of a current carrying loop.
The Biot-Savart's law equation
dB = (mu/4π)*(i dl x r)/r^3
(I'm not actually good at typing in the equations, so please just forgive me)
[/B]
Found an expression for the magnetic field due to a differential element at the centre and integrated it along the loop, and I got the expression.
Now, exactly coming to my point, is this derivation possible using Ampere's circuital law? If yes, how? If no, then what are the other situations except the cases of solenoid and toroid, where it is applicable? Please be brief and thanks in advance...
You cannot use Ampere's law for the circular loop because the symmetry is not high enough. You can use Ampere's law to find the the B field due to (a) a very long wire and its variants (long rod, strip of finite width) and (b) infinite sheet of current. I cannot think of anything else right now.
Ampere's Law for finding magnetic fields in primarily useful when you deal with high-symmetry systems. Examples of these systems are: the magnetic field perpendicular to the direction of the current in a straight wire, the magnetic field of the thick cylindrical wire, having uniform charge density, the field of a solenoid or a toroid, the magnetic field of a current conducting plane (thin plate) (contribution of infinitely many infinitesimal wires at some point). The important point about applying Ampere's law is that the magnetic field has to be circulating around some current element. The direction of [itex] \vec ds [/itex] is in the same direction with [itex] \vec dB [/itex], or, in other words, these vectors are parallel. The integration involves the total current through the area, and you can use the right hand rule to find how the magnetic field circulates (thumb indicates the direction of the current, and the curl of your other fingers will give the direction of the magnetic field). On the other hand, if you consider a solenoid, the four fingers give the direction of the current through the windings, and the thumb indicates the direction of the magnetic field (the same principle applies to the toroid). The Biot-Savart law is more "Universal", and it applies to asymmetrical systems, when Ampere's Law fails to work. Keep in mind that in the case of Biot-Savart law, the vector [itex] \vec dB [/itex] is perpendicular to both [itex] \hat {\mathbf r} [/itex] and [itex] \vec ds [/itex]. You start evaluating the Biot-Savart law by taking the cross product of [itex] \hat {\mathbf r} [/itex] and [itex] \vec ds [/itex]. When you have bended single wires, straight wires of the finite length, a circular current conducting loop, you will generally apply Biot-Savart law.
Hint: the vector [itex] \hat {\mathbf r} [/itex] is perpendicular to [itex] \vec ds [/itex] when it is a circular loop. Also, keep in mind that the cross product gives another vector perpendicular to [itex] \hat {\mathbf r} [/itex] and [itex] \vec ds [/itex]. The small element [itex] \vec ds [/itex] can be expressed as [itex] R\vec d\theta [/itex]. So, your integral will involve only the angle of revolution [itex] \theta [/itex].
Wow! Thanks, but what does that 'high symmetry' here signify?
The current flows in the cylindrical surface, long rectangular plane, straight wire, or any other geometrical shapes that will give you circular loops of the magnetic field. Normally, the current is normal to a cross-sectional area at any time and it passes through the loops around which the magnetic field is created.
Related to Magnetic field due to a current carrying loop
1. What is a magnetic field due to a current carrying loop?
A magnetic field due to a current carrying loop is a circular magnetic field that is created around a wire or loop of conductor carrying an electrical current. This magnetic field is perpendicular to the direction of the current and follows the right-hand rule.
2. How is the magnetic field strength calculated for a current carrying loop?
The magnetic field strength for a current carrying loop can be calculated using the formula B = (u0 * I * N) / (2 * r), where u0 is the permeability of free space, I is the current, N is the number of turns in the loop, and r is the radius of the loop.
3. What factors affect the strength of the magnetic field in a current carrying loop?
The strength of the magnetic field in a current carrying loop is affected by several factors, including the current, the number of turns in the loop, the radius of the loop, and the permeability of the material surrounding the loop.
4. How does the direction of the current affect the direction of the magnetic field in a current carrying loop?
The direction of the magnetic field in a current carrying loop is determined by the direction of the current flowing through the loop. The magnetic field lines follow the right-hand rule, with the thumb pointing in the direction of the current and the fingers curling in the direction of the magnetic field.
5. What are some real-life applications of the magnetic field created by a current carrying loop?
The magnetic field created by a current carrying loop has many practical applications, including electric motors, generators, electromagnets, and magnetic sensors. It is also used in MRI machines for medical imaging and in particle accelerators for scientific research.
