Magnetic field due to a long, straight wire
The discussion centers on calculating the magnetic field around a long, straight wire using Ampere's law, leading to a discrepancy between a calculated current of 9.14 MA and a textbook value of 3.72 MA. The user expresses confusion over the differing results, suggesting that the textbook might be incorrect. Another participant proposes finding the distance from the wire that would yield a magnetic field of 91.4 T when the current is 3.72 MA. The conversation emphasizes the importance of verifying calculations and understanding the relationship between current, distance, and magnetic field strength. Ultimately, the focus remains on reconciling the differences in the current values and the resulting magnetic field calculations.
Meow12
A magnetic field of 91.4 T has been achieved at the High Magnetic Field Laboratory in Dresden, Germany. Find the current needed to achieve such a field 2.00 cm from a long, straight wire.
Ampere's law: ##\displaystyle\oint\vec B\cdot d\vec l=\mu_0 I##
From Ampere's law, ##\displaystyle\oint\vec B\cdot d\vec l=\mu_0 I## where ##r## is the distance from the wire
##B\cdot 2\pi r=\mu_0 I##
##\displaystyle 91.4\times 2\pi\left(\frac{2}{100}\right)=4\pi\times 10^{-7} I##
##I=91.4\times 10^5\ A=9.14\ \rm{MA}##
But the answer given in the textbook is ##3.72\ \rm{MA}##. Where have I gone wrong?
Your work and your numerical answer look good to me.
Likes MatinSAR, Delta2 and Meow12
Thanks; I guess the textbook is wrong, then.
I also agree, but try to find the distance such that the total current is as textbook says.
I mean to find the distance from the wire such that at this distance the magnetic field is 91.4T when the wire carries 3.72MA
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
