Hithesh
- 6
- 1
Is magnetic field due to straight wire on the line of the wire itself zero? If yes, give mathematical proof.
It follows from Biot-Savart law.Hithesh said:Is magnetic field due to straight wire on the line of the wire itself zero? If yes, give mathematical proof.
The formula for calculating the magnetic field due to a straight wire on the line itself is B = (μ0 * I) / (2π * r), where B is the magnetic field, μ0 is the permeability of free space, I is the current flowing through the wire, and r is the distance from the wire.
The direction of the magnetic field due to a straight wire on the line itself is perpendicular to the wire and forms concentric circles around the wire. As you move away from the wire, the magnetic field becomes weaker and the circles become larger.
The magnetic field is inversely proportional to the distance from the wire. This means that as the distance increases, the magnetic field decreases.
The strength of the magnetic field is directly proportional to the current flowing through the wire. This means that as the current increases, the magnetic field also increases.
Yes, external magnetic fields can influence the direction and strength of the magnetic field due to a straight wire. This phenomenon is known as magnetic induction and can be observed in electromagnetic devices such as transformers.
