Magnetic field due to two looped wires
In summary, the conversation revolves around finding the magnetic field at an arbitrary z and taking its second derivative. The equation for B(z) found using the Biot-Savart law is the same as the one found by the person asking the question. However, when taking the second derivative, the result does not equal zero as expected. The person trying to solve the problem also tried using Amperes law but it did not seem to be the correct method. The conversation ends with confusion and the possibility of a typo in the equation.
physicsjock
89
I'm just studying past exams for my physics exam in a few days.
I've been struggling with this question
http://img823.imageshack.us/img823/7469/45633341.jpg
The first thing i did was use the Biot-Savart law to find the magnetic field at z=0, or at ±d/2 away from z=0
I found the field for each loop seperately and since the bottom loop was orientated in the opposite direction to the above loop it was the negative of the above field. Since the dl' vector faced the opposite way when observing from z=0,
So then when i added the two fields together ofcourse they canceled but there's no way this is right,
It says to find the derivative of B wrt z AT z=0, my equation doesn't have z in it as i found the field a distance z = ±d/2, so I suppose I could change the d/2 to z, but ill at z=0 they will still cancel get B=0 at that point so the derivative would also be zero.
In the last part it asks for the second derivative of z, with a new d, so this makes it clear my equation is wrong, haha, because mine either has d OR z
The equation i found using biot-savart for the top loop was,
B(d/2) = [itex]\frac{μIR^{2}}{2(R^{2}+\frac{d^{2}}{4})^{3/2}}[/itex]
and the bottom was just negative it
Should I be trying to find the field at an arbitrary z? If i do that, and z>d/2 then will the field be the field in the z direction of the bottom loop plus the field due to the top loop? and in the equation for the bottom loop the distance vector will have an extra d term right?
Is there an easier method I'm not seeing?
Thanks in advanced
Yes, you HAVE to find the field at an arbitrary z since the derivatives of B(z) w.r.t. z are needed.
The magnetic field at any location is the superposition (addition) of magnetic fields due to each coil.
I just made the equations, I set z=0 to be z= -d/2 (in my equations)
then I had the previous equation i posted + the same equation replaced with z = (z+d) for the second loop
When i worked through that i got the first derivative was zero.
But the second derivative I've been messing with for like 40 minutes and it's no where near zero
It doesn't work because the z's are either gone, due to the second derivative, or squared due to the second derivative, product rule.
Ill attempt to write what i did haha, B(z) = [itex]\frac{μIR^{2}}{2(R^{2}+z^{2})^{3/2}}[/itex] + [itex]\frac{μIR^{2}}{2(R^{2}+(z+d)^{2})^{3/2}}[/itex]
So the axis is set on one of the loops, so in the question where z=0 will be z=-d/2 in the equations
the first derivatives will give a 2zC + (2z+2d)C where C is all the other stuff
-dC + (-d +2d) = 0
But then the second derivative
the first two terms with the first derivative of the large part will give
2C + 2C = 4C
Then the other two terms when the second derivative is taken of the bigger thing will give
4z^2 A + (2d+2z)^2A = 2d^2 where A is the other stuff of the second derivative
and yea not zero, I expanded everything to see if there was a mistake with just leting all the other stuff = constants but I got the same result.
was what i did wrong to find the field?
I tried using amperes law, but I don't think that's the right way to do it at all, the field would be Iu/2Pir for a loop of radius r,
taking r to be z then the second loop would give B Iu/2Pi(z+d) and that doesn't seem right
I found the equation for B(z) on my own, and what I got is the same as what you got.
However, I don't understand how you got this,
What I got for the first derivative wasn't that simple.
I got,
[tex]\frac{\partial B(z)}{\partial z} = -\frac{3}{2} \mu I R^2 ((d+z)(R^2 + (d+z)^2)^{\frac{-5}{2}} + z(R^2 + z^2)^{\frac{-5}{2}})[/tex]
And this becomes zero when [itex]z = \frac{-d}{2}[/itex]
Oh cool,
was you way to find the field easier then biot-savart?
The C I set to be everything besides the (d+z) and z, because when you sub in z= -d/2 everything they are both multiplied by the same things, so i just set them to C to save worrying about it.
But yea the second derivative is giving me problems
I double checked with wolfram,
http://www.wolframalpha.com/input/?i=d^2/dz^2+(+(R+z^2)^(-3/2)+++(R+++(z+d)^2)^(-3/2))
and its what i got, when i sub it doesn't give 0,
I get
http://www.wolframalpha.com/input/?...))-6/(d^2/4+R)^(5/2)&lk=1&a=ClashPrefs_*Math-
Thats just treating the inital terms as constant, so just a constant.
Does that mean the B is bad?
I used Biot-Savart.
Oh, OK. But keep in mind that the C includes z terms, so you can't treat C as a constant when taking the second derivative.
I get
Thats just treating the inital terms as constant, so just a constant.Does that mean the B is bad?
I tried this, for the case when z = 0,
http://www.wolframalpha.com/input/?...>0,+d+->+(8+mu+i)/(R+5+Sqrt[5])}&a=i_Variable
And this, for the case when z = -d/2
http://www.wolframalpha.com/input/?...5]),+d->+(8+mu+i)/(R+5+Sqrt[5])}&a=i_Variable
I don't get zero either.
I'm not very familiar with Wolfram Alpha, maybe I'm doing something wrong with it.
Or maybe, like you said, there's a typo in the problem.
My links didn't display properly in the previous post. Here they are again,
z=0 case
z=-d/2 case
Edit: I figured out how to correct the links in the previous post. They work now.
Thanks for your help,
Yea for the second derivative i used two constants C and A.
Its weird cause like, the writer would of done the question and then found that at that weird d it =0 at the second derivative.
It doesn't make sense aswell, how could the first derivative be zero at that point and not the second,
Thanks again for your help
Well, it can happen. For example, think of an object thrown upwards against gravity. It's going to fall back down. If the displacement upwards is taken to be positive, then the acceleration is -g, and remains constant for the whole duration of its motion. The velocity is initially positive as it goes up, but becomes zero when it reaches the maximum height, and then becomes negative as it falls down. At the maximum height, the velocity, which is the first derivative of displacement w.r.t. time, is zero, but the acceleration, which is the second derivative of displacement w.r.t. time, is non-zero (-g ).
FAQ: Magnetic field due to two looped wires
What is a magnetic field?
A magnetic field is an invisible force field that surrounds a magnet or electric current and exerts a force on other magnets or moving electric charges.
How is a magnetic field created?
A magnetic field is created by moving electric charges, such as the flow of electrons through a wire, or the alignment of atoms in a magnet.
How does the magnetic field due to two looped wires work?
When two wires carrying electric current are looped together, the magnetic fields produced by each wire interact with each other, creating a net magnetic field that is stronger in some areas and weaker in others.
What factors affect the strength of the magnetic field due to two looped wires?
The strength of the magnetic field depends on the amount of current flowing through the wires, the distance between the wires, and the shape and orientation of the wires.
What are some applications of the magnetic field due to two looped wires?
The magnetic field due to two looped wires is used in various technologies, such as electric motors, generators, and transformers. It is also used in medical imaging, such as MRI machines, and in particle accelerators for scientific research.
