boroscots
- 1
Two loops carry identical currents counter-clockwise, I and share the same radius, R. They are separated by the distance R with the z axis passing through the center of each loop. Find the magnetic field at a point x distance above the center of the two loops in terms of I, R, and x.
a) Use superposition from known results or the Biot-Savart law.
b) Find the value of x that extremizes the magnetic field by an appropriate calculus-based argument and the magnetic field at that point.
c) Prove this point is a maximum or minimum using an appropriate calculus-based argument.
dB = [(mu knot)/4*pi]*(I ds x rhat)/r^2
and perhaps (1+x)^n approximately = 1+ nx + n(n-1)x^2/2! + ...
From what I understood, using Biot-Savart's law, B = [(mu knot) * I ] / [R * (1 + ( R/2 + x )^2 / R^2 )^3/2] using z=R/2 +x and factoring out R^2 from the following equation...
B=[mu knot * IR / (R^2 + z^2)^3/2]
If this is correct, I thought to use the approximation to say that at x<<R, x=0 yields a magnetic field... 5 * mu knot * I / 8 * R. (solving part b)?
How do I go about determining if this is a maximum or minimum (assuming what I've done so far is correct)?
Thank you!
