Magnetic field generated by an infinitely long current-carrying wire
The discussion revolves around understanding the magnetic field generated by an infinitely long current-carrying wire, specifically questioning the existence of a radial magnetic field component (Br). Participants emphasize that the magnetic field is typically tangent to circles around the wire, as indicated by the right-hand rule, and argue that symmetry and Ampère’s law can be used to show that Br is zero. There is a consensus that while figures may depict a radial component, it does not imply its existence, and the radial contribution to the line integral is zero due to the nature of the magnetic field. Some participants express confusion over the application of symmetry arguments and Ampère’s law, while others suggest using Gauss's law for magnetic fields as a clearer approach. Ultimately, the conversation highlights the need for a rigorous argument to demonstrate that the radial magnetic field component is indeed zero.
  • #31
bob012345 said:
Please give us that argument? I would be interested. Thanks.
I have purposefully not written out those arguments since this is the homework forums and may be part of what the OP needs to do. As @vela says, Gauss’ law for magnetic fields also works and I still prefer the pure symmetry arguments.
Since there seems to be some popular demand for this though, I might summarize in a PF Insight in the future.
Likes hutchphd and bob012345
  • #32
vela said:
Figure 12.15 The possible components of the magnetic field B due to a current I, which is directed out of the page. The radial component is zero because the angle between the magnetic field and the path is at a right angle.
I assume they mean the radial contribution to the line integral is zero. The fact that the dot product is zero does not directly imply that the radial field is zero. This is badly stated. What is the text?
Likes Orodruin
  • #33
Yeah, that's what I realized when I read the sentence more carefully after first posting it. In the discussion below the figure in the OpenStax textbook, it's explained how to deduce the radial component vanishes.
Likes hutchphd
  • #34
Orodruin said:
You can do that, yes. What I was referring to was an argument using Ampere’s law on integral form, which is also possible.
Actually, scratch that. I found a hole in that argument. Pure symmetry or using Gauss law for magnetic fields is the way to go.
Likes bob012345 and hutchphd
  • #35
I still don't understand how you can have a radial component. I thought the magnetic field was always tangent to a circle around the current.
  • #36
The discussion has been, as I understand it, about how to prove there is no radial component, not that such a radial component exists.
Likes hutchphd
  • #37
This is strictly true only for a straight wire.
To also repeat, you need an argument to show that this is the case for the straight wire. The rule you are referring to does not pop out of nowhere - it needs to be motivated and before that has been done you cannot say that it is the case. You are asked to show this. You cannot show something by just saying that it has to be like that. You need an argument.
  • #38
According to my problem in post #1, it is talking about a long straight wire, but yet the solution still considers a radial magnetic field.
  • #39
You can prove that the radial magnetic field is zero, using Gauss's law for magnetic fields. Take as gaussian surface a cylinder with the wire at the cylinder axis. What is the flux of magnetic field through this cylinder and what gauss's law for magnetic fields tell us that it should be equal to?
  • #40
Yes, considers then rejects the radial field.
Again, just because the drawing has a radial field does not mean the book is telling you the solution has a radial field and we have been trying to tell you that is not the case any more than all possible answers on a multiple choice test are all correct simply because they are written down.
Likes Delta2
  • #41
The problem is that you know the solution without knowing how to demonstrate that it is the solution. Your argument is referring to it as prior knowledge, but you are not able to demonstrate where that knowledge originated. Just because they have drawn a radial component in the picture does not make it non-zero. It is your job to compute it and thereby conclude that it is zero from first principles rather than by adherence to dogma.
  • #42
Without a doubt, ##B_r ## must be equal to 0
Maybe some esoteric methods take time to study to understand
But as mentioned in the post above, there is a relatively simple method that can be used, the Gaussian law of magnetism and the principle of symmetry.
I removed the original attached image as it might not be appropriate in this homework help discussion forum.
Likes Delta2
  • #43
I would not call symmetry arguments ”esoteric”. Some of them do take time to understand though but the basic principle is very simple.
Likes alan123hk
  • #44
Said and done. This summarizes the necessary background of pseudo vectors vs vectors, discusses why the magnetic field is a pseudo vector, and uses a reflection symmetry to conclude that the components along the wire and in the radial direction are equal to zero (you don’t even need the other symmetries of the wire to conclude this - you do need them to conclude that the strength only depends on the distance from the wire).
https://www.physicsforums.com/insights/symmetry-arguments-and-the-infinite-wire-with-a-current/
Likes berkeman, alan123hk and Delta2
