toomuchfries
- 3
Find an expression for the magnetic field of a hollow finite solenoid carrying uniform current with n turns (there is no top or bottom surfaces and the turns a very closely winded) at a point arbitrary P both inside and outside. Let's just say windings around a hollow pvc pipe.
I can use either biot savarts law and/or magnetic vector potential for surface currents. I'll use griffiths notation 3rd edition equations 5.39 and 5.64 respectively.
I'll attempt this in cylinderical coordinates. Since the current is uniform. I'll use the
[itex]\vec{A}\left(\vec{r}\right)=\frac{1}{4\pi}\int\frac{\vec{K\left(r'\right)}}{\tau}da'[/itex]
Current density [itex]\vec{K}[/itex] is in the [itex]\hat{\phi}[/itex]
so [itex]\vec{K}=\frac{nI}{z'}\hat{\phi}[/itex] ? Since current is uniform.
[itex]\tau=\left|r-r'\right|[/itex]
[itex]r=s\hat{s}+s\phi\hat{\phi}+z\hat{z}[/itex]
[itex]r'=s\hat{s}?[/itex]
[itex]da'=sd\phi'dz'[/itex]
Where the limits of phi' is 0->2*pi and z' is 0 -> L (length of cylinder)
