Magnetic field of a rotating disk with a non-uniform volume charge
In summary, the conversation discusses a problem related to classical electrodynamics, specifically involving cylindrical coordinates and Ampere's law. The participants discuss various attempts at solving the problem, including using Laplace equations for cylindrical coordinates and the Green's function method. Suggestions are given, including using Stokes Theorem and taking advantage of cylindrical symmetry. The conversation ends with a request for a solution or advice on how to approach the problem.
Light bulB 6626
Consider a thin disk ( ## d \ll R ## , with thickness ## d ## and radius ## R ## ), with volume
charge distributed as ## \rho_{f}=k(R-s)(d-z)^{2} ## , where ## s=\sqrt{x^{2}+y^{2}} ## and the coordinate origin ## (x, y, z)=(0,0,0) ## is at the center of the disk. (The ## z ## axis is normal to the circular bases of disk). When this disk rotates around
the ## z ## axis with angular speed ## \omega, ## answer the following questions:
(a) Find the free current density ## \vec{J}_{f} ##
(b) Show that ## \nabla^{2} \vec{B}=-\mu_{0} \nabla \times \vec{J}_{f} ## is satisfied in this case.
(c) Using (b), find ## \vec{B} ## near the disk, at ## z \simeq d / 2 \ll R ##
## \nabla^{2} \vec{B}=0 ## (outside the disk).
## \nabla^{2} \vec{B}=-\mu_{0} \nabla \times \vec{J}_{f} ## (inside the disk)
This was a problem introduced during my classical electrodynamics course.
I am not 100% sure, but I think I've solved up to problems (a) and (b) as below.
(Note that I tried to follow the notations in Introduction to Electrodynamics (Griffiths) :(a) We use cylindrical coordinates ## (s, \phi, z) ## , with unit vectors ## \hat{r}, \hat{\phi}, \hat{z} ## .
## \vec{J}_{f} = \vec{J} = \rho \vec{v} = \rho s w \hat{\phi} ## .
## \therefore \vec{J}_{f}=k(R-s)(d-z)^{2} \rho s w \hat{\phi} ##
(*I am not absolutely sure whether ## \vec{J}_{f} = \vec{J}=\vec{J}_{f}+\vec{J}_{b}+\vec{J}_{p} ## holds in this problem.)
(b) ## \nabla \times \vec{B} = \mu_{0} \vec{J} ## (Ampere's law)
## \nabla \cdot \vec{B} = 0 ##
( ## \because ## there are no magnetic monopoles)
## \nabla \times (\nabla \times \vec{B}) = - \nabla^{2} \vec{B} + \nabla (\nabla \cdot \vec{B})=- \nabla^{2} \vec{B} ##
## \therefore \nabla^{2} \vec{B}=-\mu_{0} \nabla \times \vec{J}_{f} ##*****************************************************************
> I have been pondering on question (c) for more than a full day, but I couldn't get a clear solution. Here are some of my (partial) attempts:
1. **Laplace equation for cylindrical coordinates**.
## \nabla^{2} \vec{B}=0 ## (outside the disk).Solve the Laplace equation for components of ## B ## , with boundary conditions obtained from
> I haven't tried this approach since because I am not familiar with solving Laplace equations for cylindrical coordinates, (also, the calculations seemed too tedious and complicated for the problem.)
2. Greens function method.
(I am not familiar with this method, but a friend of mine (a graduate from my school) advised me this method. I do not perfectly understand the Greens function method, but I was able to come up with this formula, using **some analogies** (with ## V ## and ## \vec{A} ## ) from Introduction to Electrodynamics* (Griffiths).## \nabla^{2} V=-\frac{\rho}{\epsilon_{0}} ## ## \Longrightarrow ##
## V(\mathbf{r})=\frac{1}{4 \pi \epsilon_{0}} \int \frac{\rho\left(\mathbf{r}^{\prime}\right)}{|\vec{r} - \vec{r}^{\prime}|} d \tau^{\prime} ##
## \nabla^{2} \mathbf{A}=-\mu_{0}\mathbf{J} ##
## \Longrightarrow ## ## \mathbf{A}(\mathbf{r})=\frac{\mu_{0}}{4 \pi} \int \frac{\mathbf{J}\left(\mathbf{r}^{\prime}\right)}{|\vec{r} - \vec{r}^{\prime}|} d \tau^{\prime} ##
Therefore
## \nabla^{2} \mathbf{B}=-\mu_{0} \nabla \times \mathbf{J}_{f} ##
## \mathbf{B}(\mathbf{r})=\frac{\mu_{0}}{4 \pi} \int \frac{(\nabla \times \mathbf{J}_{f})\left(\mathbf{r}^{\prime}\right)}{|\vec{r} - \vec{r}^{\prime}|} d \tau^{\prime} ##
I have tried this method, but was unable to proceed since the integral (if my calculations were correct) involved an elliptic integral. I tried to use the approximation ## z \simeq d / 2 \ll R ## to simplify the integral (- expanding it using the taylor expansion, then keeping terms upto order 1), but couldn't find a subtle arrangement of terms.
I am a undergraduate, and I am still learning/practicing how to approach these kind of problems. Any suggestions about solving the problem welcome. I would be very grateful if some kind user will provide a solution/ or a detailed advice for problem (c). Thank you.
You might look at Stokes Theorem. The ##\nabla^2\mathbf{B}## clearly has to point along ##z## so look at the area integral in the xy plane. Not sure this will get you much but the lhs of (b) was made for this kind of thing.
P.S. you can also use cylindrical symmetry. This screams make the area integrated a disk of radius ##s## for any value of ##s##.
[edit] because ##\rho(s,z)##, ##\nabla^2\mathbf{B}## will also have a ##\hat{s}## component.
Related to Magnetic field of a rotating disk with a non-uniform volume charge
1. What is a magnetic field?
A magnetic field is a physical phenomenon created by moving electric charges. It is a vector field that describes the strength and direction of the force that a magnetic object experiences in the presence of a magnet.
2. What is a rotating disk with a non-uniform volume charge?
A rotating disk with a non-uniform volume charge is a type of system where a disk-shaped object is rotating and has a varying distribution of electric charges within its volume. This can be caused by different factors such as the material properties of the disk or external influences.
3. How does a rotating disk with a non-uniform volume charge create a magnetic field?
When a disk with a non-uniform volume charge rotates, the moving charges create a current, which in turn creates a magnetic field. The strength and direction of this magnetic field depend on the distribution of the charges and the speed of rotation.
4. What is the relationship between the magnetic field and the non-uniform volume charge in a rotating disk?
The magnetic field created by a rotating disk with a non-uniform volume charge is directly proportional to the distribution of the charges. This means that the stronger the variation in the charge, the stronger the magnetic field will be.
5. How can the magnetic field of a rotating disk with a non-uniform volume charge be calculated?
The magnetic field of a rotating disk with a non-uniform volume charge can be calculated using mathematical equations such as Ampere's law or Biot-Savart law. These equations take into account the distribution of charges, the distance from the disk, and the speed of rotation to determine the strength and direction of the magnetic field at a specific point in space.
