Magnetic Field of Four Parallel Wires
In summary, the magnetic field at the center of the square is the sum of the magnetic fields of the four currents that are located at the corners of the square.
Angie K.
108
Four long straight wires located at the corners of a square of side l = 27.8 cm carry equal currents I0 = 16 A perpendicular to the page as shown in the figure above. Determine the magnitude of B at the center of the square.
B=mu0/2pi*I/r
I know that using the equation above I will get the magnetic field. But does it matter that it's asking for the magnetic field at the center? Also when doing the x and y component, I am not sure how to find the angle. Is it just 90 because it's perpendicular?
Sort of. Again :smile: !
What angle are you referring to ? 90 degrees with respect to what ?
The magnetic field is linear in the sense that individual contributions can simply be added. But you have (as you do) to keep in mind that they are vectors, so you need some vector addition pizazz. Who knows you don't have to calculate anything or only one field strength if you do is smartly...
But it's best to befgin with the field at the center due to just 1 of the wires and then see how to continue
Angle with respect to length of wire and magnetic field. So the total magnetic field would be the sum of field of all 4 currents?
Yes, the angle wrt the wire is 90 degrees. So all four contributions are in the plane of the page.
But 90 degrees wrt "and magnetic field" is a little unclear to me. If not to say contradictory. What precisely do you mean ? Perhaps a drawing ?
And yes "the total magnetic field would be the sum of field of all 4 currents"
I think I just had the wrong approach with the angle wrt to the wire statement that I said.
The radius of the point in the middle of the square and each current in .1966 m
So I can use the equations for the x and y components to solve this problem?
x components would be B1x+B2x+B3x+B4x (magnetic field of the 4 currents summed up)
y components would be B1y+B2y+B3y+B4y (magnetic field of the 4 currents summed up)
And to find Bx of each current I would use -Bcos (theta)
and to find By of each current I would use +Bsin (theta)
Then the total B would just be the square root of Bx^2+By^2
Where B =mu0*I/(2pi*r)
Is that the right approach?
Well, it's a start. How do you take the directions (into/out of page) of the currents into account ?
And I still think you can make this easier for yourself by making a drawing; see how the four ##\vec B## add up.
FAQ: Magnetic Field of Four Parallel Wires
1. What is a magnetic field?
A magnetic field is a region in space where a magnetic force can be felt. It is created by moving electric charges, such as electrons, and is represented by magnetic field lines.
2. How does the magnetic field of four parallel wires differ from that of a single wire?
The magnetic field of four parallel wires is stronger than that of a single wire because the wires are producing magnetic fields in the same direction, resulting in an additive effect. Additionally, the magnetic field within the space between the wires is also stronger due to the wires being closer together.
3. What factors affect the strength of the magnetic field in this system?
The strength of the magnetic field in this system is affected by the current flowing through the wires, the distance between the wires, and the material of the wires. Increasing the current or decreasing the distance between the wires will result in a stronger magnetic field.
4. How can the direction of the magnetic field be determined in this system?
The direction of the magnetic field in this system can be determined using the right-hand rule. If you point your thumb in the direction of the current flow, your fingers will curl in the direction of the magnetic field.
5. How is the magnetic field of four parallel wires used in practical applications?
The magnetic field of four parallel wires is used in many practical applications, such as in electromagnets, generators, and motors. It can also be used in magnetic levitation systems, where the repelling force between the wires and a magnet can be used to levitate objects.
