Dell
- 590
find the expression for the magnetic field at a distance z on the axis which passes through the centre of a disk, with a radius of R, and a charge density σ, the disk is rotating at an anular velocity of ω.
http://lh4.ggpht.com/_H4Iz7SmBrbk/SivHVn0m_fI/AAAAAAAABC0/9sgJmbkoJK8/s720/Untitled.jpg
could someone tell me if this is all done correctly?
the equations i am going to use are
1)F=ILxB
2)f=qvxB
3)biot savar
1st stage i want to express the charge q,
q=σπR2
now i use
f=qvxB=σπR2vB ( the angle is 90 degrees constant)
f=σπR3Bω
F is also ILB so i know that IL=σπR3ω
now using biot savar
dB=(μI*dlxr)/4πr3)
now for I*dl i want to substitute the expression i found earlier, with R being my variable, not that sure about this...
dB==(μσπR3ωdR)/4π((R2+z2)0.5)3)
dB=(μσR3ωdR)/4((R2+z2)1.5)
B=(μσω/4)*∫R3dR/(z2+R2)1.5
after integration i get
B=(μσω/4)*(1+z2/(z2+R2))*(z2+R2)0.5 with my limits being R from 0 to R
and eventually i get
B=(μσω/4)*[(1+z2/(z2+R2))*(z2+R2)0.5-2z]
i have never solved anything of this sort and hope everything i have done is okay, thanks
1)F=ILxB
2)f=qvxB
3)biot savar
q=σπR2
now i use
f=σπR3Bω
dB=(μI*dlxr)/4πr3)
