Magnetic Field of Rotating Coil
In summary, magnetic field values can be determined using a search coil. This method relies on measuring the total charge passing through the coil in a given time interval while the magnetic flux linking the windings changes due to either motion of the coil or a change in the value of B. For example, a 61-turn coil with a resistance of 194Ω and cross-sectional area of 44.5m2 was rotated in a uniform field, resulting in a total charge of 4.76E-4C passing through the coil. Using the formula emf = -change in flux, the magnetic field value can be calculated. However, further information and a drawing may be necessary for a complete solution.
dukesolice
Moved from a technical forum, so homework template missing
Magnetic field values are often determined by using a device known as a search coil. This technique depends on the measurement of the total charge passing through a coil in a time interval during which the magnetic flux linking the windings changes either because of the motion of the coil or because of a change in the value of B. As a specific example, calculate B when a 61-turn coil of resistance 194Ω and cross-sectional area 44.5m2 produces the following results: A total charge of 4.76E-4C passes through the coil when it is rotated in a uniform field from a position where the plane of the coil is perpendicular to the field to a position where the coil's plane is parallel to the field.
I know the formula emf = -change in flux, but I don't know how to get the change in the area and how to use the charge given.
Hello duke, :welcome:
This looks a lot like homework, so please post there and use the template ! Show what you've done so far and we'll help you.
In exchange: when the coil is parallel to the field, flux is zero.
And charge is the integral of current over time - the time needed to turn the coil !
A drawing helps immensely, too !
Related to Magnetic Field of Rotating Coil
1. What is a magnetic field of a rotating coil?
The magnetic field of a rotating coil is a phenomenon that occurs when an electric current flows through a coil of wire, creating a magnetic field around the coil. This magnetic field is induced by the movement of the electrons in the wire and can be manipulated by changing the direction or strength of the current.
2. How is the magnetic field of a rotating coil measured?
The magnetic field of a rotating coil can be measured using a device called a magnetometer. This device detects the strength and direction of magnetic fields and can be used to map out the magnetic field produced by a rotating coil.
3. What factors affect the strength of the magnetic field in a rotating coil?
The strength of the magnetic field in a rotating coil is affected by several factors, including the number of turns in the coil, the amount of current flowing through the coil, and the size and shape of the coil. The material of the core around which the coil is wound can also affect the strength of the magnetic field.
4. How is the direction of the magnetic field in a rotating coil determined?
The direction of the magnetic field in a rotating coil is determined by the direction of the electric current flowing through the coil. The right-hand rule can be used to determine the direction of the magnetic field, where the thumb points in the direction of the current flow and the curled fingers point in the direction of the magnetic field.
5. What are the practical applications of the magnetic field of a rotating coil?
The magnetic field of a rotating coil has many practical applications. It is used in generators to convert mechanical energy into electrical energy, and in electric motors to convert electrical energy into mechanical energy. It is also used in devices such as speakers, transformers, and magnetic sensors.
  • Electromagnetism
  • Electrical Engineering
  • Electromagnetism
