Magnetic field of Solar System planets
In summary, the magnetic field of the planets decreases with time because their cores cool off and are no longer able to generate a strong magnetic field. However, the Earth's magnetic field remains strong because it has a hot, molten core and a large rotating core. This is due to its size and the tidal friction caused by its large moon. While this may seem to explain why the Earth has a strong magnetic field while the other rocky planets do not, there are still some unanswered questions. For example, Venus, which is similar to Earth in many ways, also has a molten core but does not have a strong magnetic field. This is likely due to its slow rotation and thick lithosphere, which suppresses plate tectonics and
Pedro de la Torre
Hello. I am reading a paper which says that only Earth (between the rocky planets) keep a strong magnetic field and it arose an question on this:
Why does the magnetic field of the planets decrease with time in such planets?
Why the magnetic field of the Earth is the only one which keeps strong?
Astronomy news on Phys.org
because their cores have cooled off
because it still has an actively rotating core
Likes rootone
Anticipating the obvious next question, why so for Earth and not the other rocky planets?
1, It is the largest of the rocky planets.
2, It has a very large Moon. which causes tidal friction; contributing to keeping the interior hot.
Likes Borg and davenn
The reason a hot core is important is because the Earth's magnetic field is believed to be generated by the dynamo effect. This requires a hot, molten mantle/core.
This is slightly misleading in two ways.
First, Venus is almost the same as the Earth (dimensions, composition, gross structure) and is thought to have a partially molten core close to the size of the Earth's, though there are some marginally plausible core compositions that could have solidified. However, if the core is molten, as seems likely, then Earth's "large" size cannot explain the absence of a field from Venus, while it does explain it for Mercury, Mars and the moon.
Assuming there is a molten core, it seems there is no significant convection - a necessary condition to initiate and maintain a geodynamo. In that case why no dynamo? It has been suggested that Venus's slow rotation inhibits convection, but this is generally discounted. (For example, here.) The more likely explanation is the thick lithosphere. This supresses plate tectonics and thereby restricts the loss of internal heat, a necessary condition for convection.
Secondly, the Earth's internal heat is primarily a consequence of residual thermal energy from accretion, radioactive decay and core formation. The contribution from tidal flexing is insignificant. (See, for example, Chapter 9, [page 1150] Basaltic Vulcanism on Terrestrial Planets.)
Likes anorlunda and davenn
Related to Magnetic field of Solar System planets
1. What is the magnetic field of the Earth?
The Earth's magnetic field is approximately 25 to 65 microteslas, with the strength varying at different points on the surface. It is generated by the movement of molten iron in the Earth's outer core.
2. How does the magnetic field of other planets in the solar system compare to Earth's?
The magnetic fields of other planets in the solar system vary greatly. Some, like Mars and Mercury, have very weak magnetic fields while others, like Jupiter and Saturn, have much stronger fields. Some planets, like Venus, do not have a significant magnetic field at all.
3. Is the magnetic field of the solar system constant?
No, the magnetic field of the solar system is not constant. It is constantly changing and can also be affected by solar storms and other external factors. The Earth's magnetic field, for example, has reversed its polarity multiple times in the past.
4. How does the magnetic field of a planet affect its atmosphere?
The magnetic field of a planet can play a crucial role in protecting its atmosphere from being stripped away by the solar wind. The Earth's magnetic field, for example, helps to deflect the solar wind particles, preventing them from reaching and damaging the atmosphere.
5. Can we use the magnetic field of other planets for navigation?
Yes, we can use the magnetic field of other planets for navigation, just like we use the Earth's magnetic field. However, the strength and structure of the magnetic fields of other planets may differ, so different methods may need to be used for navigation on each planet.
  • Astronomy and Astrophysics
