Magnetic field of solenoid and a coil with multiple turns
In summary, Ampere's law is usually OK for coils longer than a certain length, but Biot-Savart is better for short coils.
rooks
Member advised to use the formatting template for all homework help requests
Hi!,
I have a question for you geniuses (geniusi?)
Why are there two different equations to find the magnetic field of a solenoid and a coil with multiple turns?
(According to my textbook)
The equations for each are
Solenoid:
Coil with multiple turns:
Why are they different? Is there a physical difference between a coil and a solenoid?Thanks for the help.
Hello Rooks, :welcome:
Don't double-post, please.
And google a bit before you post: your expressions apply to different kinds of coil: the first one for a long coil
the second for a very short coil
[edit] Google is your friend. Maybe you'll like section 9.4 here
Ok, then where is the threshold? When does a coil become too long to use the 2nd equation? When does a solenoid become too short to use the 1st equation?
Also, I meant why does the length matter and make the equation different?
No threshold but a gradual transition.
There is an intermediate range where neither can be used. The first one stops being useful if the solid angle of the end turn becomes too large.
The second one stops being useful if it's significantly lower than 2 ##\pi##.
You have to use Biot-Savart for "short" coils. You can use Biot-Savart for "long" coils but Ampere's law is usually OK.
You can use Ampere's law if the length of the coil is long enough to warrant ignoring the B field outside the coil.
As BvU say, there is a transition.
And BTW both approaches allow you to determine the B field on the axis, nowhere else.
Related to Magnetic field of solenoid and a coil with multiple turns
What is a solenoid?
A solenoid is a type of electromagnet that consists of a coil of wire with multiple turns, typically wrapped around a cylindrical core, that produces a magnetic field when an electric current is passed through it.
How is the magnetic field strength of a solenoid determined?
The magnetic field strength of a solenoid is determined by the number of turns in the coil, the current passing through the coil, and the permeability of the material inside the coil. The strength of the magnetic field is directly proportional to the number of turns and the current, and inversely proportional to the permeability.
What is the purpose of using multiple turns in a coil?
The purpose of using multiple turns in a coil is to increase the magnetic field strength. Each turn of the coil adds to the overall magnetic field, resulting in a stronger field than a single turn coil.
How does the magnetic field of a solenoid compare to that of a single-turn coil?
The magnetic field of a solenoid is much stronger than that of a single-turn coil. This is because the solenoid has a larger number of turns, resulting in a more concentrated and stronger magnetic field.
Can the direction of the magnetic field be changed in a solenoid?
Yes, the direction of the magnetic field in a solenoid can be changed by reversing the direction of the electric current passing through the coil. This is known as the right-hand rule, where the direction of the magnetic field is perpendicular to the direction of the current flow and can be determined by curling the fingers of your right hand in the direction of the current, and the thumb will point in the direction of the magnetic field.
