Magnetic field outside a wire coiled on an iron cyl.
In summary, the current in a wire creates an electromagnetic field which is stronger and more focused than the field produced by a ferromagnetic core.
dmriser
50
If we consider the common electromagnet that is made by passing current through a wire coiled around an iron core, I wonder what effect produces more magnetic field:
1. The field produced outside the solenoid due to the current in the wire
2. For this effect I don't insist that the object is iron or even ferromagnetic, just capable of having a net magnetism induced (ie: electron spin aligned along the axis of the solenoid in the direction of the field, paramagnetism i believe). This alignment produces an external magnetic field.
My question is which effect dominates and provides the larger contribution to the total magnetic field outside?
I hope the question is clear.
Thank you,
David
Well just as you said current in wire creates an electromagnetic field , now it would be sufficient with the wire wrapped in a coil alone to make the field , iron cores are used just to make the whole device many times more efficient and powerful.
Now right you said that the wore around the iron of ferromagnetic core make the electrons in the iron align and produce a net magnetic field , the iron become a magnet.
Now let's be clear without the current going in the wire there would be no field outside so I can't say that iron is responsible for the field , the field is there because of the flow of charge through a conductor in the first place , iron is just a material assisting in this creating the magnetic field stronger and more focused.(depends on the shape of the iron core)
It is hard to say what makes a bigger contribution to the field outside , rather the flow of current makes one and the iron just adds o the sum.
By the way you don't always need a core to make the electromagnetic field going good.Cores are needed where lower frequencies of the em spectrum are used like in power electromagnets or transformers. (electromagnets can also come with dc where there is no frequency)
Using higher frequencies you can have the field pretty string even without the addition of an iron core like some high frequency coreless transformers where two special field coils are placed near each other and the high frequency em field induces current in the secondary winding.Radio transmission works similarly too.
Also going in higher frequencies makes the iron pretty bad because a lot of the energy is lost as heat.So there is a limit to how high iron/ferrite materials can go.
Related to Magnetic field outside a wire coiled on an iron cyl.
1. What is a magnetic field?
A magnetic field is a region of space around a magnet or electric current where magnetic forces can be observed. It is created by the movement of electrically charged particles.
2. How is a magnetic field created by a wire coiled on an iron cylinder?
The magnetic field is created by the flow of electric current through the coiled wire. As the current flows, it creates a magnetic field around the wire. The iron cylinder amplifies the strength of the magnetic field due to its high magnetic permeability.
3. What direction does the magnetic field point outside the wire coiled on an iron cylinder?
The magnetic field points in a circular direction around the wire, with the direction of the field determined by the direction of the current flow. The iron cylinder also concentrates the magnetic field within its core, making it stronger in that direction.
4. How does the number of coils on the wire affect the strength of the magnetic field?
The more coils there are on the wire, the stronger the magnetic field will be. This is because the magnetic field created by each coil adds to the overall strength of the field. Additionally, more coils will also lead to a higher current flow, further increasing the strength of the magnetic field.
5. Can the strength of the magnetic field outside the wire be increased by using a different material instead of iron?
Yes, the strength of the magnetic field can be increased by using a material with a higher magnetic permeability than iron. This means that the material can be more easily magnetized and will amplify the strength of the magnetic field. Materials such as nickel and cobalt have higher permeability than iron and can be used to increase the strength of the magnetic field outside the wire.
