Sho Kano
- 372
- 3
How come the magnetic field outside a solenoid is practically zero?
I've read reasons along the lines of:
-The magnetic field cancels out on the outside.
Of course the net force cancels out, but what if you have an object placed on just one spot? The force on that object clearly is not 0 because it is closer to one side of the solenoid than the other.
-The field lines spread outside the solenoid so much, that the density goes to zero as the solenoid gets longer.
This seems like it only happens in cases that say you start out with a solenoid of fixed length and current, then extend it out to a very large number. If you increase the current at the same time you are stretching the coil, the magnetic flux density will remain somewhat constant won't it? Now what if you don't stretch the solenoid at all? What if you had a solenoid of infinite length to begin with- is the field still 0 outside?
Another question: Why is the field outside nearly zero at all? Each current running through each section will contribute to a magnetic field outside...
